Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 01-07-2014, 09:13 PM   #21
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I forgot to plug in my intake vanos solenoid for a week after ccv...I looked and looked...my damn mechanic found it in 5 secs.
Are you sure you attached the engine ground straps by #6 cylinder when you did plugs and coils?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-07-2014, 09:45 PM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Do you have an OBDII scan tool that can display Live/Real Time data?
Read this about OBDII tools - http://forum.e46fanatics.com/showthread.php?t=967204
Did you possibly swap the O2 sensor connections when doing other work on the engine?
Check the 1st link below in my signature for other problem areas.
Also read this - http://forum.e46fanatics.com/showthr...139&highlight=
Not sure where you are located, might be problem fuel due to super cold weather.
Old 01-08-2014, 08:02 PM   #23
Jjsa8199
My Ride: 323ci
I'm located in Vegas .. Also it's having random misfires and telling p1250.. No I don't have a scanner but my personal mechanic does and he lives across the street from me
Jjsa8199 is offline   Reply With Quote
Old 01-12-2014, 07:27 PM   #24
Jjsa8199
My Ride: 323ci
So I have replaced everything coils spark plugs fuel pressure regulator fuel filter both o2 sensor crank case valve/oil separator and all hoses..
Still misfiring showing codes of o2 sensor and o2 circuit mal function Click image for larger version
Old 01-12-2014, 07:41 PM   #25
Jjsa8199
My Ride: 323ci
So did a first smoke test and and found a leak then replaced that and fuel filter and fuel pressure regulator
And still misfiring
Old 01-12-2014, 08:03 PM   #26
Jjsa8199
My Ride: 323ci
It's saying misfire on bank 4-5-6. O2 sensor bank 2 circuit mal function
Old 01-12-2014, 08:28 PM   #27
lszlszx
My Ride: 1.8T, XC70
I believe there are fuses for the O2 sensors, check those.
Did your mechanic advise you on this?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 01-13-2014, 07:38 AM   #28
Jjsa8199
My Ride: 323ci
No he did not
Old 01-13-2014, 07:43 AM   #29
Jjsa8199
My Ride: 323ci
May I have the location of the fuse
Old 01-17-2014, 10:53 AM   #30
Jjsa8199
My Ride: 323ci
What do you guys think about this Click image for larger version
Old 01-17-2014, 11:07 AM   #31
Willie00328I
My Ride: 2000 328I sedan
I changed my air distribution/spreader o-rings, they all looked very bad. It's pointless to do a CCV job and not replace these as they all add up to a big vacuum leak. Also change all of your vacuum hoses, one at a time so you don't mix up anything. Mine were brittle and split.
http://m.ebay.com/itm/181303727449?nav=SEARCH&sbk=1
Willie00328I is offline   Reply With Quote
Old 01-17-2014, 11:08 AM   #32
My Ride: Lexus
^wtf is that. i wouldn't trust that for $70
Old 01-27-2014, 09:08 AM   #33
Jjsa8199
My Ride: 323ci
Thank you for everyone's input and help on my last project now this symbol have piped up..Click image for larger version
Old 01-27-2014, 09:11 AM   #34
Willie00328I
Looks like your transmission is in limp mode. Mine does that sometimes. When it does I turn the car off for a minute then it goes away. I still don't know the cause.
check engine light, misfires, o2 sensors, rough idle
