Old 01-31-2014, 09:29 AM   #1
e46kingimran
My Ride: BMW 3 25 CI
Car revs automatically but cannot accelerate
Hello,
I am having an issue with my 2004 BMW 3 25 Ci. I was away for a few weeks and left the vehicle outside in the brutal Canadian winter. When I got back, I started the car and it started normally. However, the engine seems to be revving on its own in idle and when i press the gas, nothing happens. Is this a cold weather issue? Did something get damaged because of the cold? Any help would be great.
Thanks,
e46
e46kingimran is offline   Reply With Quote
Old 01-31-2014, 08:03 PM   #2
lszlszx
My Ride: 1.8T, XC70
It's not a typical cold weather issue, but the cold this winter isn't typical either.
Try to get your car into a warm garage and keep it there for a day.
Then disconnect the battery for like 10 minutes and see what happens.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 02-01-2014, 10:40 AM   #3
Dave1027
My Ride: '06 IR zhp coupe
Maybe check the throttle body and the wiring to it?
Old 03-10-2014, 04:27 PM   #4
BeemerMeUp
My Ride: 330i Sports Edition
Revving @ idling
It's the Idle Control Valve : ICV ... make sure to clean it until it rattles inside it's cage... mine have the same problem... because I was afraid I might break it it has stuck open or close -and not rattling around ... after reading the common symptoms. I figured out it was in the idle control valve for IDLING problems. I'm going to clean this after I get home... with all the revving
BeemerMeUp is offline   Reply With Quote
cold weather, problem
