Old 02-13-2014, 01:45 PM   #1
BiggBoss1024
My Ride: 1999 328i
Unhappy Weird Movement and Feelings
Hello again,
When I first purchased my 1999 E46 328i, it had a terrible wheel wobble and a above 80mph or so, the whole car would shake like it was going to fall apart. Brought it in and the dealer balanced all 4 wheels and did a full wheel alignment. All of the wheel wobble went away, and the shaking above 80 stopped completely. Now, all of a sudden, the wheel wobble is back between 20 and 40 mph. The shaking above 80 is not, however. Also, I have noticed when I hit the brake pedal suddenly the whole car kind of jolts when the brakes grab, and the wheel turns itself. In addition, some other things I've noticed are: brakes squeak most of the time, when the temperature outside is under 20 degrees or so, the brakes stick until the car is warmed up a bit or until I drive on them which makes the engine rev a lot.
Car has 83k miles and this is my first major issue I've noticed in the 4 months of owning it.
Thanks!
BiggBoss1024 is offline   Reply With Quote
Old 02-13-2014, 01:52 PM   #2
Pole position
My Ride: E46 330ci
As for the vibration, clunk, and steering itself- you need to replace your forward control arm bushings.
Also sounds like you need a brake service based on the mileage of your car.
Shut up and drive
Pole position is offline   Reply With Quote
Old 02-13-2014, 02:00 PM   #3
BiggBoss1024
My Ride: 1999 328i
Ok, thanks for the quick response. Are the bushings expensive or is it just the labor that is?
Old 02-13-2014, 02:18 PM   #4
WDE46
My Ride: '13 128i, '04 330Ci
The bushings are <$100 or $150 preinstalled in new housings (recommended for a DIYer). It's not a hard DIY if you have a jack. You shouldn't be paying more than $300 for FCABs installed IMO.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 02-13-2014, 02:47 PM   #5
BiggBoss1024
My Ride: 1999 328i
Thank you. Do you have any suggestions of reliable websites to order from?
Old 02-13-2014, 02:50 PM   #6
WDE46
Check out our site sponsors.
ECSTuning
TurnerMotorsport
BMAParts
AutohausAZ
TischerBMW (GetBMWParts.com)
Be mindful of whether you're buying bushings with housings or just the bushings.
For future use, go to RealOEM.com with your serial number (last 7 characters of VIN). You can lookup part numbers that way.
Old 02-13-2014, 03:08 PM   #7
BiggBoss1024
My Ride: 1999 328i
On ECS Tuning, there are 3 different sets of front control arm bushings (with brackets). There is a set made by Vaico for $53, a set made by Lemförder for $92, and then there are the official BMW ones for $155. As money is tight, do you recommend going with the BMW ones, or have you heard of those other brands.
Old 02-13-2014, 03:11 PM   #8
BiggBoss1024
My Ride: 1999 328i
And are the brackets they are referring to the same as the housings you were referring to?
Old 02-13-2014, 03:24 PM   #9
Yewzer B Lewzer
My Ride: 2003 325i
If you have access to a hydraulic shop press you can get polyurethane FCAB's for about $75 without the brackets and press them into your brackets. Look for powerflex or UUC polyurethane FCAB's.
These parts are under a lot of stress, don't cheap out or you will be doing the job again soon.
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 02-13-2014, 03:30 PM   #10
WDE46
Lemforder no question
Old 02-13-2014, 03:31 PM   #11
WDE46
Yes
Old 02-13-2014, 03:32 PM   #12
BiggBoss1024
My Ride: 1999 328i
Thank you all, I'm gonna go with the Lemförders. This will be my first DIY with the car so wish me luck. Is it something very hard to do with just a jack?
Old 02-13-2014, 03:32 PM   #13
WDE46
Search for E46 FCAB DIY. Read a few and gather your tools.
Use jack stands with your floor jack. Don't get under a car with just a jack supporting it. I also don't recommend using the spare tire jack for maintenance procedures.
Old 02-13-2014, 05:37 PM   #14
diSsss
My Ride: 2000 316i
About the braking. Could be many things. Brake discs that are bend, sticky brake cilinder (quad ring that pulls the piston back might be bad)
Servicing the brakes might show the problem.
Good luck with the DIY!
diSsss is offline   Reply With Quote
Old 02-13-2014, 06:49 PM   #15
330ism
My Ride: 2004 330I ZHP
I know this May sound crazy and it may not fix your issue but I had a vibration while braking and a slight pull and it ended up being just low air pressure. Easiest thing to start with(just saying) GL
330ism is offline   Reply With Quote
Old 02-13-2014, 10:11 PM   #16
BiggBoss1024
My Ride: 1999 328i
Do you guys recommend nitrogen in the tires? Dealer will put it in all 4 for $40. Or is it just a gimmick because there will always be some air in there since they can't get the tire completely flat before they put it in.
Old 02-13-2014, 11:09 PM   #17
WDE46
Air is over 70% nitrogen haha. It's a gimmick for street cars. Don't pay that.
Old 02-13-2014, 11:15 PM   #18
Marshmallow
My Ride: Ehhh...
Seriously only $40 for nitrogen in the tires? I would pay that just to say I have it.
Marshmallow is offline   Reply With Quote
Old 02-13-2014, 11:25 PM   #19
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Not sure if serious.
If serious then wtf
Old 02-14-2014, 11:02 AM   #20
Marshmallow
My Ride: Ehhh...
If serious then wtf
Maybe...maybe not.
alignment, brakes, shake, steering, wobble
