Old 03-23-2014, 03:54 PM   #1
yoyomin
My Ride: 2002 330i
Worth doing VANOS at 240K?
My 330i is approaching 240K miles very soon. Everything works fine except an annoying vibration at 550RPM idle when the car is fully warmed up. No misfires, just a constant vibration throughout the car. Putting the transmission in neutral will bump up the idle a bit to maybe 600RPM and the vibration goes away right away. I checked the engine mounts and they seems fine, I can't shake the engine by hand. Some threads mentioned that the culprit might be VANOS seals, but at this mileage is it worth doing the VANOS? To my best knowledge the VANOS has never been done before.
yoyomin is offline   Reply With Quote
Old 03-23-2014, 04:05 PM   #2
Twichel04
My Ride: 1999 323i
If they have never been done, then you really should... Soon. VANOS seals can start going bad as early as 20k miles. They're not hard to do, and pretty cheap too.
OrientBlau 323i - M3 bumper - Eibach Pro Kit - Style 63 X5 wheels - 19x9 & 19x10
Twichel04 is offline   Reply With Quote
Old 03-23-2014, 04:10 PM   #3
thefrog1394
My Ride: e46- 1999 323i
Originally Posted by yoyomin View Post
My 330i is approaching 240K miles very soon. Everything works fine except an annoying vibration at 550RPM idle when the car to fully warmed up. No misfires, just a constant vibration throughout the car. Putting the transmission in neutral will bump up the idle a bit to maybe 600RPM and the vibration goes away right away. I checked the engine mounts and they seems fine, I can't shake the engine by hand. Some threads mentioned that the culprit might be VANOS seals, but at this mileage is it worth doing the VANOS? To my best knowledge the VANOS has never been done before.
Really depends what your plans are for the car. My car has about 260k miles and I long ago made the decision to upkeep the car to a lower standard. Meaning prioritizing maintenance items that affect the reliability and daily driving enjoyment over more particular items. Bottom line is that it doesn't make financial sense to spend $2,000 fixing door rust on my car when it is worth maybe $2,500-$3,000 total.
Of course this is a decision you have to make yourself. I haven't personally done vanos but I also have the 323i, which from what I've read, has a lot less noticeable issues from a bad vanos vs the 330i.
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 03-23-2014, 04:22 PM   #4
yoyomin
My Ride: 2002 330i
Thanks for the reply. Actually me too I'm putting reliability maintenance/repairs above performance issues. Cooling system is up to date, and now I guess I'll do a tranny fluid change as my first spring project.
Just saw a $100 VANOS kit including valve cover gaskets on ebay. Guess I'll do it when I'm bored.
Old 03-23-2014, 05:01 PM   #5
Knight
My Ride: '05 330Ci | '01 325i
It's hit or miss with the VANOS seals. Some people do it at much lower mileages and notice a difference while others don't notice a difference even after doing it at a higher mileage.
I'm at 117K and notice no rattle or dips in power, so I decided to let it be. When I hit 200K or maybe 250K I'll probably replace the entire unit with a fully rebuilt one as PM.
Knight is offline   Reply With Quote
Old 03-23-2014, 06:43 PM   #6
Manolito
My Ride: '04 325iT Manual
At this age and mileage, it is likely that your VANOS O-rings leak, but leaking O rings should not cause a vibration when pulling at idle. I would definitely do those O-rings next time you need a valve cover gasket. It will probably help your midrange power and gas mileage.
If my understanding is correct, the only VANOS problem that I would expect to cause an idle problem is varnish buildup in the VANOS gears and thrust bushings that keeps the cam from going all the way back to its idle timing. There are any number of products that will claim to help remove engine varnish. I don't think any of those products work very well. I recently soaked the mechanicals from an e36 VANOS in methylene chloride paint remover. It helped only a little. Note that I am talking about the steel mechanicals that are bolted to the cams, not the aluminum VANOS actuator (piston body). The piston body may collect some sludge, but it does not get hot enough to gather hard varnish buildup.
The vibration under loaded idle is more likely a vacuum leak causing one or two cylinders to misfire at idle. Try spraying starting fluid around that intake manifold and see if the engine reacts to it.
Manolito is offline   Reply With Quote
Old 03-23-2014, 07:58 PM   #7
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
The vibration is most likely from bad motor mounts
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
Old 03-23-2014, 08:35 PM   #8
czarmar
My Ride: '99 323i
I just did the VANOS seals yesterday on a 284K 323i. Was it worth it? At this point I'm not sure. I had a leaky VCG, so I was going to take care of that anyways, and the seals were pretty dried up. However, the VANOS pistons didn't seem to have a ton of play in them, and once I bolted everything back together, my 323i didn't suddenly do an impression of a 330i. If you have a leaky VCG, then it takes about an extra hour to replace the VANOS seals. Beisian Systems FTW. Their tutorial is superb.
Make sure you have a pointy X-acto knife blade. I was trying to cut those seals out with a utility knife blade, and it was definitely not the right tool for the job.
'99 323i Sedan 293K miles (RIP)
2014 i3 BEV
czarmar is offline   Reply With Quote
Old 03-23-2014, 08:38 PM   #9
beeemerdude
Banned User
My Ride: Cabrio. Stick.
OP's Q almost sounds like a "Should I just drive my E46 into the ground" ? non?
beeemerdude is offline   Reply With Quote
Old 03-23-2014, 09:51 PM   #10
yoyomin
My Ride: 2002 330i
At this mileage do I have any other choice?
Old 03-23-2014, 10:08 PM   #11
Sedan Hussein
My Ride: e46
Do it, its fairly cheap and easy. 240k is impressive
Sedan Hussein is offline   Reply With Quote
Old 03-23-2014, 10:20 PM   #12
Vabmwe46
My Ride: Bmw 2002 325i sedan
Do you need to use that special tool to change vanos seals? How do u kno if ur seals are bad due to them being inside engine almost?
Vabmwe46 is offline   Reply With Quote
Old 03-23-2014, 10:30 PM   #13
Sedan Hussein
My Ride: e46
The vise liners? I think they're just for the rattle kit. At 240k, your seals are probably bad.
Old 03-23-2014, 10:34 PM   #14
Vabmwe46
What are vise liners? I have a 02 325i sedan with 107** .. I plan on changing my VCG soon (preventative maint) but want to do the vanos.. I noticed my gas milage is not to good.. Jus changed fuel filter couple months ago.. & feels like the engine is losing power..
Old 03-23-2014, 10:41 PM   #15
Sedan Hussein
My Ride: e46
http://beisansystems.com/
Old 03-23-2014, 10:42 PM   #16
Vabmwe46
Appreciate
Old 03-24-2014, 09:15 AM   #17
Willie00328I
My Ride: 2000 328I sedan
Check your heat shield around the brake booster. Mine came loose and was rattling loud at low Rpms.
Willie00328I is offline   Reply With Quote
Old 04-12-2014, 02:47 PM   #18
czarmar
My Ride: '99 323i
Just to follow up on the VANOS seals, I think my car's midrange power has really increased in the weeks after I did the seals. I think it just took a little while for the DME to adjust. So, I now recommend the VANOS seals after my initial tepid reaction.
2014 i3 BEV
Old 04-12-2014, 04:01 PM   #19
jeepo23
My Ride: 2008 X3, 6 Speed
http://i6motorworks.com/index.php?ro...tegory&path=59
jeepo23 is offline   Reply With Quote
Old 04-13-2014, 12:01 AM   #20
john-117
My Ride: 330i
This
john-117 is offline   Reply With Quote
idle, vibration
