Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 05-04-2017, 09:07 AM   #41
jfoj
My Ride: 330CiC, M5, X5, E93
Something is wrong other than a central part like the MAF.
For Bank #2 to have such a high LTFT, there much be a vacuum leak that is only impacting Bank #2. There are 3 vacuum ports on the back, underside of the intake near runner #6 that have caps and hoses, it is not uncommon for these hoses and caps to split and even fall off.
Smoke test will show you the leak in seconds.
If there is clearly no vacuum leak, then there is something going on with the Bank #2 of the engine.
STFT can and do move around a lot depending on the driving conditions. I usually do not focus too hard on STFT unless they are hard fixed above say +15% or higher.
Old 05-04-2017, 09:25 AM   #42
se93
My Ride: BMW 328ci AW MTECH2
Yea rhat must be the case. LTFT on bank 2 immediately goes to 9.4. I am going to spray some carb cleaner towards the back of the intake manifold to see if can hear any idle changes
There is a rubber plug and a vacuum line that connects on the back side drivers side corner of the intake manifold.
Will have to check that rear portion of the intake manifold
Regards,
Mark Perez
se93 is offline   Reply With Quote
Old 05-04-2017, 09:45 AM   #43
jfoj
Forget carb cleaner or any other sprays. All the air leaks on these engines tend to be from the underside of things and the sprays rarely hit the spot.
Smoke Testing is easy, fast and accurate. Will cost you less than $15 in parts.
See the Smoke Test section in this thread - http://forum.e46fanatics.com/showthread.php?t=897616
Here are some reference threads about the ports on the bottom of the intake:
http://forum.e46fanatics.com/showthr...ghlight=intake
http://forum.e46fanatics.com/showpos...9&postcount=36
http://forum.e46fanatics.com/showpos...53&postcount=2
Intake removal -
http://forum.e46fanatics.com/showthread.php?t=1116990
http://forum.e46fanatics.com/showthread.php?t=901967
http://forum.e46fanatics.com/showpos...6&postcount=19
Old 05-04-2017, 10:04 AM   #44
se93
But if there was a leak in one of those three rear ports, wouldn't that affect both bank 1/2?
Regards,
Mark Perez
Old 05-04-2017, 10:09 AM   #45
jfoj
No
Old 05-04-2017, 11:45 AM   #46
se93
I am also going to check the vacuum line from fuel pressure regulator to fuel filter
I have not looked at that area since last fuel filter change (30K)
Regards,
Mark Perez
Old 05-04-2017, 12:26 PM   #47
jfoj
Hose to the FPR has little bearing on your problem. As a test, cap off the FPR connection at the F connector and you will see little to any change.
Old 05-05-2017, 05:36 PM   #48
se93
Hi guys
In my search to resolve the issue with the high LTFT's, with the engine running, i removed the oil cap and noticed very little difference with idle. Engine kept running smoothly with no issues
Is this good or bad in regards to having or not having a vacuum leak?
Regards,
Mark Perez
Old 05-05-2017, 06:13 PM   #49
jfoj
Hi guys
So from my experience, while watching the Fuel Trims, removing the oil fill cap at a warm idle on a "good" engine that has a tight crankcase without any air leaks, the STFT will start around +2% or +5% and the STFT will immediately jump up by approximately +20% or slightly more.
Old 05-05-2017, 08:27 PM   #50
se93
LTFT and MAF - Correct Levels?
Hey guys
I decided to inspect the oil dipstick oring and observing the oring it has several cracks and a few pieces missing . Could this cause such a vacuum leak to elevate LTFT's? Will see what happens when i install the new one tomorrow
Regards,
Mark Perez
Old 05-06-2017, 02:49 PM   #51
se93
I got the new o-ring installed with no issues. I did take off the oil cap again with OBD Fusion and STFT started to rise substantially. Got to 21. You can hear the idle decrease somewhat and engine tone slightly changes. But other than that and with the new oil dipstick o-ring LTFT values are still the same.
I did notice upon startup after reinstalling everything, i heard a light bang coming from my cold air intake piping. Did it once
Back to the drawing board
Regards,
Mark Perez
Old 05-06-2017, 04:56 PM   #52
jfoj
Best to get Freeze Frame and Logs so it will be move obvious what is going on.
Have you checked the power brake booster out as a source of vacuum leaks?
Section 8 in this link - http://forum.e46fanatics.com/showthread.php?t=897616
Old 05-06-2017, 05:01 PM   #53
se93
No codes as of yet. LTFTB2 went up to 10%
Will take a look at section 8 now
Regards,
Mark Perez
Old 05-06-2017, 05:22 PM   #54
se93
I have a question regarding the sucking jet pump. If i remove the vacuum hose that connects to the upper air intake boot, ( comes from the sucking het pump) should there be strong vacuum enough to pull your finger onto the opening of the vacuum line?
Regards,
Mark Perez
Old 05-06-2017, 05:35 PM   #55
jfoj
Yes there is vacuum on the sucking jet pump inlet. The sucking jet pump is basically a vacuum amplifier.
Sucking Jet Pump Links
http://forum.e46fanatics.com/showthread.php?t=1061188
http://forum.e46fanatics.com/showthread.php?t=523763
http://www.bimmerfest.com/forums/sho...d.php?t=578766
It is actually the power brake booster leaking that can be a vacuum leak that is hard to pinpoint unless you know what to look for.
Old 05-06-2017, 05:45 PM   #56
se93
Next time i use the car will be listening carefully for any sounds as indicated above
My car works flawlessly. Solid cold/warm starts, drives good and since installing the lower air boot i have not seen any 1188/1189 codes that previously showed and also to this moment no codes whatsoever
To me, it cannot be the CCV I still have the MAF in mind but would want to test with a known properly working unit to know for sure as this is a pretty pricey part
I may also order a new oil cap just in case
Regards,
Mark Perez
Old 05-06-2017, 06:13 PM   #57
se93
I have not checked fuel pressure but for normal maintenance will be replacing the fuel filter next week. You never know as a clogged fuel filter can make it difficult for the fuel pump to do its job.
Thinking out loud here to see if the culprit of this fuel trim issue is finally discovered
Regards,
Mark Perez
Old 05-06-2017, 06:16 PM   #58
jfoj
Fuel pump/filter issues usually cause Bank #1 to be Leaner than Bank #2 due to the fuel entering the rail from the rear of the engine. Yours appears to be opposite of this.
Data would be useful.
How old are the Pre-cat O2 sensors?
Old 05-06-2017, 06:49 PM   #59
se93
My car has 81,218 miles
I have never replaced them since i purchased the car years ago
Regards,
Mark Perez
Old 05-06-2017, 06:59 PM   #60
jfoj
Data = OBDII data. Freeze Frame and Logs.
What OBDII tool are you using?
We are spinning our wheels trying to extract data here.
ltft, maf, stft, torque pro
