Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 05-06-2017, 07:02 PM   #61
se93
My Ride: BMW 328ci AW MTECH2
LTFT and MAF - Correct Levels?
Data = OBDII data. Freeze Frame and Logs.
What OBDII tool are you using?
We are spinning our wheels trying to extract data here.
OBD Fusion
Car has no codes so no freeze frame. Will get some logging done and send over
Regards,
Mark Perez
se93 is offline   Reply With Quote
Old 05-06-2017, 07:09 PM   #62
jfoj
My Ride: 330CiC, M5, X5, E93
Logs would be very helpful.
How old are the Pre-cat O2 sensors?
Old 05-06-2017, 07:12 PM   #63
se93
I have never replaced them since i have been the owner
Regards,
Mark Perez
Old 05-06-2017, 07:27 PM   #64
jfoj
81,000 miles, this is a 328?
What year is this car?
Did the sit for a long time?
Old 05-06-2017, 07:30 PM   #65
se93
2000 328ci
I lived in Puerto Rico and bought the car about 10 years ago. Car had 51k when i purchased it. Spanking brand new
I moved to Texas and brought it with me
It was a show car and had very little use in Puerto Rico. Here in Texas its my daily driver now
Regards,
Mark Perez
Old 05-06-2017, 07:56 PM   #66
se93
Sent a number of files
Your PM is full
Regards,
Mark Perez
Old 05-07-2017, 11:03 AM   #67
Archbid
My Ride: 2003 330cic
Your PM is full
Put the files on dropbox and post a shareable link here on the forum. Instructions in jfoj's guide
Archbid is offline   Reply With Quote
Old 05-07-2017, 11:11 AM   #68
se93
LTFT and MAF
Here is the dropbox link:
https://www.dropbox.com/sh/amg3e3pyr...gowmtQx8a?dl=0
Regards,
Mark Perez
Old 05-07-2017, 05:40 PM   #69
se93
I Just picked up a fuel pressure gauge to measure pressure.
It does leak a bit in the connection between the gauge and hose but with the key on (not starting up) i see oressure goes up to about 50 and as fast as it rises y comes back down to 0.
I turn the car on and get around 50-55 psi from what i could see as i had to turn off the car to stop fuel from continuing to seep out. There is a leak on the fuel gauge but looks like there is a fuel system issue
Need to get some teflon tape to cover the gauge threads and retest
Regards,
Mark Perez
Old 05-07-2017, 07:22 PM   #70
se93
I fixed the fuel pressure tester leak and tested fuel pressure with key on (engine not running, see pictures) and took a video with engine on and gradually accelerating to 3500rpm
This is fuel pressure with engine on @ idle
Engine on and gradually accelerated to 3500 rpm
Regards,
Mark Perez
Old 05-07-2017, 07:51 PM   #71
jfoj
Residual fuel pressure spec 20 minutes after engine has been shut off - Fuel pressure >3 bar or >43.51 PSI
If the residual fuel pressure drops below this, there is likely a check valve or injector leaking.
Old 05-07-2017, 09:23 PM   #72
se93
Will an injector leak reveal fuel around the injector area or can this occur and not see any fuel leakage?
Should i worry about the fast rate in which fuel pressure decreases when engine is not running as seen in the previously posted pictures? Can this issue cause the high LTFT values? The check valve is part of the fuel pump itself, correct? Thus a bad check valve would require a new fuel pump. If that was the case, can we get a walbro fuel pump and mate it with the factory fuel pump housing assembly? Would this be a good, reliable alternative to not have to purchase the original fuel pump unit?
Regards,
Mark Perez
ltft, maf, stft, torque pro
