Old 05-02-2014, 07:32 PM   #1
Callmetofo
My Ride: 2001 e46ci
Maf same as hyundai?
Hello everyone!
My Car info:
2001 325ci 5spd
Disclaimer: I'm in college, and my bmw has been Breaking My Wallet
So i was told by my local shop that my MAF was faulty and that I need to replace it, and they quoted me $450 for parts. So decided to do some research on some alternative ways to fix my problem for cheaper. I am reviving an old thread because it's old and i wanted to see if more people have recently has done this.
http://forum.e46fanatics.com/showthread.php?t=783659
Here is a ebay link of the hyundai MAF that people say works for most e46s
http://www.ebay.com/itm/99-01-Hyunda...=mtr#vi-ilComp
Has anyone tried these before!?
Callmetofo is offline   Reply With Quote
Old 05-02-2014, 07:44 PM   #2
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Did you even read the first post of the thread you linked?
Cavi Mike is offline   Reply With Quote
Old 05-02-2014, 07:47 PM   #3
lszlszx
My Ride: 1.8T, XC70
Unplug your MAF sensor. Is it a 3 pin connector?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-02-2014, 08:13 PM   #4
JapanRot325ci
My Ride: 04 E46
is it me or for the past two weeks most thread was about MAF and VGC...oh man
JapanRot325ci is offline   Reply With Quote
Old 05-02-2014, 09:07 PM   #5
scarede46er
My Ride: 2001 BMW 325i ZSP
Yes the Hyundai one will work fine for your car.
Old 05-02-2014, 09:16 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Before you knee jerk on the MAF, what is the problem with the car?
What trouble codes are present?
What are the Fuel Trim values?
Do yourself a favor and do some more troubleshooting and investigating before you consider the MAF. If you do swap the MAF, keep the original one, trust me on this.
Suggest you get your own OBDII scan tool, $35 or less for a smart phone App and interface - http://forum.e46fanatics.com/showthread.php?t=967204
Also suggest you read the links below in my signature.
If I have $5 for every MAF replaced when it was not needed, I would be a rich man.
Every car I own has the original MAF still installed, never cleaned. Some over 11 years old, some with over 110k miles.
Old 05-05-2014, 02:14 PM   #7
Callmetofo
My Ride: 2001 e46ci
Hey jfoj
My codes are
P0171
P0174
P0344
A few weeks ago i removed mu disa unit and used sealer where the O ring should be,(this before i read your posts)
Todays ago i unplugged my MAF and my stalling at neutral has stopped. I did this not to fix it but to see if my maf is an issue...When i cruising in neutral my rpm stays at about 1.25rpm however at complete stop im more around .8rpm. What would you think this symptom is, in relation to my MAF and lean codes?
Thanks for your time
Jon
Old 05-05-2014, 02:52 PM   #8
jfoj
Hey jfoj
My codes are
P0171
P0174
P0344
Jon
P0171 & P0174 are lean codes. If you get these at idle, likely vacuum leak issue. Smoke test if you cannot find the leaks. Make sure you check crankcase and intake air path.
If the lean codes are while cruising 40-60 MPH, then likely the MAF is under reporting and it bad/fake/counterfeit/wrong.
P0344 is a questionable intake Camshaft Position Sensor code.
Suggest clearing codes and see if P0344 code back quickly.
Old 05-05-2014, 06:39 PM   #9
Knight
My Ride: '05 330Ci | '01 325i
For future reference, is there a Siemens/Hyundai equivalent for the 330 MAF sensor?
Knight is offline   Reply With Quote
Old 05-05-2014, 08:41 PM   #10
jfoj
Do not think there is an equivalent or reasonable option for the later model 330 with the 5/6 wire MAF. History says you BETTER stick with a BMW dealer or at least a "known" good supplier that sells Siemens "real" MAF's.
The 330's seem VERY temperamental and need the proper MAF otherwise you WILL be sorry.
Best thing to do is benchmark your current MAF at idle and under a specific cruising conditions. Note the MAF reading, RPM, temps and fuel trims. Then you can watch for changes in the future.
Old 05-05-2014, 09:01 PM   #11
Knight
Good to know, thank you. I need to start monitoring my fuel trims more closely.
Old 05-07-2014, 02:35 PM   #12
Callmetofo
My Ride: 2001 e46ci
Yes it is!
hyundai, maf, maf replacement, maf sensor
