Old 07-07-2014, 11:41 PM   #1
pb21
My Ride: 2000 323i
driveshaft wont reach diff??
hey
I have a 2000 323i. I just replaced the guibo and CSB and when attempting installation I could not get the diff end to come close enough to engage the bolts(with the transmission side bolts barely threaded onto their nuts. I tried jacking the trans/diff but that didn't work. I've tried everything I could think of but nothing has worked. When we put the 2 halves of the drive shaft back together after replacing the center bearing, my buddy tightened the nut on the shaft very very tight. I didn't think anything of it at the time but it seems to be the only thing I that would cause this problem. Is there any way the driveshaft could be shortened too much if the 2 halves are screwed in too tight? Any ideas how I can get the drive shaft to reach properly? Any help is greatly appreciated.
pb21 is offline   Reply With Quote
Old 07-07-2014, 11:58 PM   #2
havnfun328
My Ride: '99 328i, '03 M5
The nut your buddy tightened is on a splined shaft that adjusts the length of the driveshaft. Loosen it and you should be able to make it fit. When the guibo and diff ends are tight then retighten the nut on the spline.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 07-08-2014, 12:02 AM   #3
pb21
My Ride: 2000 323i
That's what I was thinking. Thanks for the help. I really needed that before going and buying a chain vice grip to loosen the damn thing. That's what he used to get it on and it worked pretty damn well. A vice wouldn't cut it and neither would a few friends holding it still...
Old 07-09-2014, 10:58 AM   #4
Tangent_
My Ride: '01 330i, '11 Z435i
Since that happened... Did you mark the driveshaft before you took it apart so it would go together exactly the same? If it got reassembled with the halves rotated in relation to each other you could get a vibration.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 07-09-2014, 11:26 AM   #5
WDE46
My Ride: '13 128i, '04 330Ci
That bolt bottoms out and only keeps the shaft from extending too far. This advice is incorrect.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-09-2014, 11:36 AM   #6
pb21
My Ride: 2000 323i
I was able to get the driveshaft back on. Yes the 2 halves were lined up properly wen we reassembled it. Now when i start the car and put it into gear the dsc light comes on and when you give it alittle gas (with the whole car still being in the air) it hesitates with no normal rpm build. Why is my driveshaft messed up? Any suggestions?
Old 07-09-2014, 11:39 AM   #7
WDE46
What else did you do to the car?
I'd put it on the ground and drive it.
Old 07-09-2014, 11:55 AM   #8
pb21
My Ride: 2000 323i
The transmission is whining when the clucth is released and there's definitely something wrong with the whole setup (driveshaft transmission differential). It does not sound right at all. I haven't done anything else to it. Just changed the guibo and center bearing.
Old 07-09-2014, 06:59 PM   #9
Tangent_
Press the DSC button to disable it. What you're doing by giving it gas while it's in the air is to the computer exactly like serious wheelspin. The front wheels aren't turning but the rear are and it's applying the brakes and cutting throttle in response. The system is working as designed.
Old 07-09-2014, 09:36 PM   #10
Simon P.
My Ride: 330i
^This. With the wheels in the air and the car in gear the DSC is seeing the rear wheels turn and the front wheels stationary. Car has no idea it's in the air, it's assuming you're a messed-up driver doing messed-up things !
Simon P. is offline   Reply With Quote
Old 07-09-2014, 09:38 PM   #11
Swater330i
My Ride: 2003 BMW 330i 5MT
Sounds exactly like dsc activating
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 07-11-2014, 12:51 PM   #12
pb21
My Ride: 2000 323i
You are all correct. The dsc was taking over. I put the car on the ground and did a very short 10ft long test drive (as the reason for my transmission whine was a serious lack of royal purple). The previous owner has not been kind... Thank you all for your help. Now on to the notorious driver side trailing arm.
323i, drive shaft, problem
