Old 09-20-2014, 01:32 PM   #1
DonofGor
My Ride: 2002 e46 330 ci conv
Power steering groan
I have a major groan from power steering when I turn the wheel especially at low speed. Have a 2002 e46 convertible 330 ci.
I think the pump is a lf 30. I have attached a picture of pump in the car. Is this the lf 30? I presume I have to untension the belt to see if there is play in the pump.
I have bought a new reservoir and fluid as it's dirty brown.
If there is no play in the pump and I change fluid do I have to change the hoses?
Cheers.
DonofGor is offline   Reply With Quote
Old 09-21-2014, 09:04 AM   #2
markusmarkus
My Ride: 2001 330Ci
I would first perform a power steering system flush. There's a DIY (or 2) on various BMW sites. Also, perform the flush in conjunction with the changing of the ps reservoir. Change the reservoir and flushing the system should take about an hour if you're handy with tools. I used 4 quarts of dino (non-synthetic) power steering fluid and 2 quarts of Redline D4ATF for the flush. No groans.
Old 09-21-2014, 05:16 PM   #3
DonofGor
Cool, I got a reservoir ordered already. Got some D4ATF coming as well. Will change reservoir and do the flush and see how things go. Will keep u posted. Thanks for replying.
Old 09-22-2014, 05:40 AM   #4
DonofGor
Should I do a flush with the old pump reservoir in and when fluid runs clear then put in the new pump reservoir?
I would think so as to minimise contamination to the new filter/reservoir with crap fluid.
Old 09-22-2014, 06:43 AM   #5
markusmarkus
My Ride: 2001 330Ci
No, install the new reservoir before doing the flush. Do not install the fluid return line that goes to the reservoir. And do not remove the plastic cap on the nipple that connects to the fluid return line. Otherwise the new fluid will pour out of the reservoir. Use non-synthetic ("dino") ps fluid for most of the flush. Once the fluid is clear switch to the Redline ps fluid.
Old 09-22-2014, 07:16 AM   #6
DonofGor
Brilliant. Thanks for the advice.
Old 09-23-2014, 06:51 AM   #7
markusmarkus
My Ride: 2001 330Ci
Yore welcome.
Old 09-23-2014, 06:51 AM   #8
markusmarkus
My Ride: 2001 330Ci
"Yore"??????? More coffee!
power steering
