Sponsored by The Tire Rack
Old 10-13-2014, 12:30 PM   #1
steven_345
My Ride: 03 318i M-Sport 5 sp
18x8.5/9.5 on E46 Coupe?
The rims are STR 601's
Front: 18x8.5 et30
Rear: 18x9.5 et35
Will they fit?
I'm open to cambering too.
Thanks for any help!
steven_345 is offline   Reply With Quote
Old 10-13-2014, 12:38 PM   #2
smilez
My Ride: e46 325i
Send a message via AIM to smilez
Yes.
smilez is offline   Reply With Quote
Old 10-13-2014, 12:53 PM   #3
steven_345
Originally Posted by smilez View Post
Yes.
Thanks! Would I need to roll the fenders?
Old 10-13-2014, 12:55 PM   #4
smilez
My Ride: e46 325i
You should be fine. Even more since you have a coupe.
Old 10-13-2014, 04:12 PM   #5
steven_345
Alright man, sounds good. Thanks again.
Almost forgot to mention, I'm lowered on coil overs, will they still fit?
Old 10-13-2014, 05:55 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
There's a lot of variable so to consider when you go lower (ride height, alignment specs, camber, driving style, tire size brand/model).. All things considered, you'd probably have to dial in just a mild bit of camber.. if want to go even lower then possibly fender modification on top of that
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-13-2014, 07:29 PM   #7
steven_345
I'm planning on going as negative as possible on the stock arms and then getting camber plates for the front, so that's fine by me too. I guess I'll have to order the wheels and play with height and camber. Thanks for the help!
Old 10-20-2014, 10:42 AM   #8
zachpeakee
My Ride: 2002 BMW 325i
Yes , they will work. I have the same wheels, but mine are 30 offset front , 20 offset rear. If I recall correctly, the coupes have a little bit more space in the fenders, as well? Don't hold me to that. But, you may need to run a little bit of stretch. I have 225/40/18 all around. Click image for larger version
zachpeakee is offline   Reply With Quote
Old 10-20-2014, 10:44 AM   #9
zachpeakee
Btw, forgot to add, I'm running stock camber controls. Max camber in back (eccentric bolt) and factory settings in front (plus the natural camber that is a by-product of lowering) . Hope I helped a little. Haha
Old 10-20-2014, 10:59 AM   #10
steven_345
Thanks for the help! Could you post a picture of the eccentric bolt? I'm not quite sure as to which one it is, because there's 2 bolts pretty close to each other. (Maybe a Dumb question?)
Also, I'm planning on running 215/35/18 and 225/40/18.
Hopefully it'll all fit, because the coil overs are going all the way down!
Old 10-20-2014, 11:02 AM   #11
zachpeakee
Quick google search will give you all you need . Haha. As requested...
Old 10-20-2014, 11:13 AM   #12
steven_345
Haha i figured I might find the wrong thing and have my axle drop out while I'm driving down the road! (Not really). Thanks again!
camber, coupe, rims, stretch, wheels
