exaust help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-16-2014, 08:31 PM   #1
jidi
My Ride: e46
exaust help
hi guys im just wondering what the difference between straightpiping and muffeler delete is and which one is better(in your opinion). also is it smart to just get a new muffler instead if i cant spend alot of money on a whole new exaust? and what else can i do to add a better sound to the car
jidi is offline   Reply With Quote
Old 10-16-2014, 10:17 PM   #2
Rob43
My Ride: 03 331Ci 5spd R1200R
A straight pipe would usually mean: A straight-ish tube from the headers all the way back.
A muffler delete would mean: You're chopping the last/rear muffler off & installing tubing to make up for the lack of the muffler.
These are two Completely different things.
So if you have little coin, start with a muffler delete. You can always hack off more exhaust stuff later if you need more sound.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-22-2014, 10:07 PM   #3
jidi
My Ride: e46
Good luck,
Rob43
is it hard to do it on my own or should i take it to a shop. thanks for your help!
Old 10-22-2014, 10:28 PM   #4
Rob43
You need to visit the forums more often.
What Bimmer are you working with ? Some E46 cars have a single tube, others have dual exhaust tubes.
You might be capable of cutting your rear muffler off, but typically the new hardware is welded back on. Thus a muffler shop does the job, shop around, prices will vary a lot.
Rob43
Old 10-22-2014, 10:32 PM   #5
rocky46
My Ride: 2003 330i
Take it to a shop and have them take care of it for you. Pricing will be at 80-130 depending on the shop. If you want to add a nice tip thats gonna be a little more $$
rocky46 is offline   Reply With Quote
Old 10-22-2014, 10:33 PM   #6
rocky46
My Ride: 2003 330i
For a muffler delete that is
exaust, muffler, muffler delete, straight pipe
