Better quality window regulators... URO Premium - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 10-17-2014, 12:53 PM   #1
bmwguru
Account Under Review
My Ride: 2004 M3
Anyone try one of these new ball-bearing roller window regulators?
http://www.eeuroparts.com/Parts/6341...51337020659AP/
bmwguru is offline   Reply With Quote
Old 10-17-2014, 01:20 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Uro Parts
Definitely not.
Old 10-17-2014, 01:37 PM   #3
bmwguru
My Ride: 2004 M3
My factory regulators didn't last very long, just looking for better options.
Old 10-17-2014, 01:55 PM   #4
orb
My Ride: 325Ci
Factory is best. Also I believe they updated the design.
orb is offline   Reply With Quote
Old 10-17-2014, 01:55 PM   #5
Dave1027
My Ride: '06 IR zhp coupe
Clean and lubricate all window tracks and sliding components
Old 10-17-2014, 02:31 PM   #6
WieGeil
My Ride: God's Chariot
I'm no enginerd, but ball bearing pulleys sound better than plastic pinwheels.
From eeuroparts:
URO premium window regulators contain a ball bearing inside the cable pulley, eliminating friction and decreasing the load on the entire system. This drastically reduces the risk of cable or pulley failure and allows the motor to operate below its capacity; thus vastly extending its usable life. This design enhancement has been validated to outlast the OEM design by more than 6 times and lasting over 200,000 cycles without any failures. (That is the equivalent of 100 years of use)
WieGeil is offline   Reply With Quote
Old 10-17-2014, 02:38 PM   #7
My Ride: Lexus
From eeuroparts:
I wonder if this was a recent design change. Cause the three URO regulators I installed on a neighbor's car last year all failed within two days. three in a row. The store ended up returning the third one and giving credit towards a Genuine one.
Old 10-17-2014, 02:49 PM   #8
Chaplian
My Ride: M56 SULEV
Nope, they're still crap. I installed a URO regulator sometime in Spring in my passenger side window. Guess which regulator failed in summer? Yep, you guessed it.
And the mode of failure? The damn cable got twined and let go.
Driver's side is still OEM with zip tie fix done as preventative maintenance. Also replaced the red clips that held the glass to the track, those were in rough shape. That one's still working fine after 11 years, knock on wood.
Chaplian is offline   Reply With Quote
Old 10-17-2014, 03:13 PM   #9
WieGeil
^ Video says the Uro Premium design is new as of September 2014, so they couldn't be the same as the ones you installed last Spring. Given all the problems, no wonder they redesigned them.
Old 10-17-2014, 04:08 PM   #10
My Ride: Lexus
Interesting. I may give them a try... providing stores arent selling old stock. Right now I have two front genuines. I did have a pair of UROs last 4 years though. So i got my moneys worth
Old 10-18-2014, 08:35 AM   #11
klax
My Ride: '04 325i
It's a crappy design to begin with. There are plenty of older cars around with more proven designs (but more expensive to manufacture) that have lasted for decades without fail. I have two older German cars (1984 and 1995 and both with around 100K miles) with their original regulators - untouched. My 325i is the only car I've ever owned that had failing regulators - although I'm sure there are other makes that fail.
I ended up buying a Dorman from Autozone. Will it fail? Probably will at some point, it's a crappy design no matter who makes it. Whomever makes it has to work within the confines of the original door and its specs. If/when the Dorman fails, Autozone will replace it under the lifetime warranty.
klax is offline   Reply With Quote
Old 10-18-2014, 08:39 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
THIS. This is a crucial step when doing the job.
And yes, URO is complete TRASH.
Old 10-18-2014, 11:08 AM   #13
Gunsnbacon
My Ride: 2001 330ci
My windows creak pretty badly and when I shut the door with the window down, they get stuck. I'm in the market for some new regulators so I'm keeping tabs on this thread. Mine get unstuck if I slam the door several times and jiggle it around, then they roll up pretty quickly. To avoid it, I barely latch the door, then just push it firmly shut until it clicks into place.
If my windows are up, no problem shutting the doors normally and I make sure all of my tracks are lubricated and all the bolts are snug.
-List of Modifications-
2001 Alpinweiss 330ci ZSP
Gunsnbacon is offline   Reply With Quote
Old 10-18-2014, 12:08 PM   #14
My Ride: Lexus
Try some of the "new" UROs and see how they hold up. I'd be interested in these new ones. Doesn't hurt to try new products that claim an improved design providing that product is not capable of leaving you stranded or hurting anyone--these are like what $60.
Old 10-18-2014, 12:57 PM   #15
Yewzer B Lewzer
My Ride: 2003 325i
I agree with the comments about lubricating the tracks, but haven't found a good product for the purpose. Any recommendations?
Yewzer B Lewzer is offline   Reply With Quote
Old 10-18-2014, 01:13 PM   #16
Gunsnbacon
My Ride: 2001 330ci
Hmm, seems just like the sedan ones? I saw you had a m3 listed as your vehicle so I was guessing they also made these for the coupes/convertibles. I can only find OEM ones for a coupe and they are about $140/ea.
I can still try these out on my xi though, passenger window is completely broken on that vehicle.
Old 03-22-2015, 07:26 AM   #17
rkneeshaw
My Ride: 330i ZHP
Half of you guys aren't paying attention. This is an updated design by Uro.
My original Uro regulators also have failed after only a couple months, and I lubed the hell out of them, so that's not really the answer and I dont believe it makes any difference.
BUT, These new Uro parts have an updated bearing design. And they come with a new lifetime warranty. I dont think you can go wrong...
http://www.oembimmerparts.com/BMW_E4...59-660prem.htm
Anyone tried these yet or seen them in person?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 03-22-2015, 07:42 AM   #18
Solidjake
Zero. Leaks.
Solidjake's Avatar
Hmm, new design doesn't seem too bad.... I might give them a shot in a month.
Old 03-22-2015, 07:53 AM   #19
rkneeshaw
My Ride: 330i ZHP
The older Uro part that I installed a year ago in my drivers side front door just failed, so I'll get this new design installed too and try it out. I'll report back if it fails.
2003 BMW 330i ZHP
Old 03-22-2015, 09:48 AM   #20
dan4081
My Ride: 2000 323i
Looks interesting...
dan4081 is offline   Reply With Quote
bmw, lifter, premium, quality, uro parts, uro premium, window regulator
