Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-25-2015, 03:17 PM   #81
UROpartsman
Account Under Review
My Ride: 1996 M3
I greatly appreciate the positive feedback from many of you in this thread.
As far as lubricants go our engineer recommended one called Krytox from Dupont, but it's pretty pricey. Has anyone tried it?
UROpartsman is offline   Reply With Quote
Old 07-01-2015, 08:51 PM   #82
RoyceG02
My Ride: Wienermobile
Does anyone with chronic power window issues like these smoke? Or for some other reason often drive around with windows down in unusual conditions like when it's raining?
RoyceG02 is offline   Reply With Quote
Old 07-01-2015, 09:22 PM   #83
jfoj
My Ride: 330CiC, M5, X5, E93
2 problems.
#1 - Engineers, they do not typically have much real world experience and often expect/take things WAY over the top. As you mention Krytox is $$$$.
#2 - Krytox is a grease! Where are you going to apply grease in the window tracks or on the gaskets that will not make a mess?? This is why I am looking either a spray silicon, spray silicon with PTFE or a spray PTFE. What I need to see is what kind of residue/hydrocarbons is in the spray mix.
I will have some some Dupont Silicon with PTFE and Dupont spray PTFE hopefully next week.
Old 07-02-2015, 06:58 AM   #84
Jaundiced Outlook
My Ride: has a tailgate
As jfoj has already mentioned, you definitely don't want to get Krytox anywhere near the window glass. It will make a mess and be a PITA to remove.
Krytox, however, is fantastic for maintaining rubber seals away from windows. I use it on my wife's Eos; the convertible top has a bunch of seals and six years later they're still in great shape.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 07-02-2015, 10:06 AM   #85
zander271
My Ride: 6spd ZHP/5sp XI
Like this ?
http://www.amazon.com/dp/B00MWLDALQ/..._DmvLvb2VBQC4F
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 07-02-2015, 10:09 AM   #86
zander271
2 problems.
What does BMW use?
Old 07-02-2015, 10:11 AM   #87
WDE46
My Ride: '13 128i, '04 330Ci
I have a hard time believing any engineer recommended Krytox for lubing these things. It's absurdly expensive.
BTW, JFOJ a grease is exactly what you're looking for. Silicone will not last. Greases don't spontaneously go everywhere and get on **** so mess isn't really a concern.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-02-2015, 10:36 AM   #88
jfoj
I am not looking for a grease and DO NOT want a grease.
There is NO WAY I would ever put a grease in a window track or even on the gaskets.
Grease will attract dirt and hold dirt, I have no problem reapplying something as necessary, this will be needed when a vehicle becomes 5+ years old.
But it is also about CLEANING as well as lubricating. Quite often I wipe down the gaskets and mating surfaces usually with something like a towel with Windex or something with Ammonia to cut greases and oils as well as remove dirt and any of the top layers of rubber that have started to break down.
Then in the past I have typically used a spray silicon, however, PTFE based products are more readily available then they were many years ago.
All it takes is a wipe down of the gasket surfaces and mating surfaces to see the residue that you clean off to get an idea as what is going on.
I see there are 3 areas to focus on.
1. Rubber sealing gasket surfaces.
2. Window guides, on sedans and wagons, these are present, on coupes and convertibles these are not present.
3. Window regulators and slides in the door.
For #1 & #2, there should be no grease IMHO.
For #3 I would expect that the window regulator to be pre-lubricated from the vendor and if any additional lubrication is required that cannot be put in the correct location, the vendor should probably provide a small, single use portion of the proper lubrication.
For coupes and convertibles the vertical guide rails in the doors may need some form of grease, however, I really do not see problems with the coupe and convertible window regulators, so I think these models are not part of the focus here.
So this pretty much leaves area #1 and #2 as the main area focus.
I would expect the vertical window guides to hold the PTFE better than sealing gaskets. Also not having to work on a sedan or wagon with a failed regulator, it is unclear if the vertical slide channel material wears out, bunches up, shrinks or shifts and becomes tight over time. Or does the window cock in the vertical guide channels for some reason.
I think manually raising the window up and down with your hand while the regulator is out of the door would be quite telling as to what may be going on.
Seems the problems are mostly with "breaking" the window loose for opening, kind of like getting a stuck window open in your house that has not been opened for a long time. It often takes a lot of effort and energy.
Old 07-02-2015, 11:17 AM   #89
Jaundiced Outlook
Originally Posted by zander271 View Post
Trust me, you don't want that stuff on glass. That's the same Krytox version I use on our Eos, and I accidentally got some on a window. It's made from inert PTFE so normal cleaning agents are nearly useless.
2001 325iT 5-Speed
Old 07-02-2015, 11:51 AM   #90
zander271
Gotcha.
Ok after using "the Google" it seems that a lot of people are using White lithium grease.
Old 07-02-2015, 04:10 PM   #91
jfoj
Gotcha.
What are people using grease on? The window regulator or the guide channels and gaskets?
I really must be missing something because there should be no additional grease required for a window regulator or and not any used on the guide tracks or gaskets.
Old 07-02-2015, 04:20 PM   #92
Saintluk2
My Ride: 2000 323i sedan
I sprayed White Lithium grease on all the moving parts of the window regulator only.
Saintluk2 is offline   Reply With Quote
Old 07-02-2015, 04:36 PM   #93
glhx
My Ride: 2002 330ci
[QUOTE=UROpartsman]First off, thank you taking the time to write me! The URO team is made up of passionate enthusiasts such as yourself, and we definitely understand where you're coming from.
We recently developed our "URO Premium" brand to accomplish exactly what you're talking about***********: provide replacement parts that are superior to OEM at a reasonable price. Our URO Premium window regulators accomplish this, as well as our URO Premium metal engine pulleys, aluminum t-stat housings, etc. However, 99% of our product line is not engineered to be superior to OEM. These parts are designed to be comparable to OEM for less money, creating great value for the DIY enthusiast. However, the cost savings is not due to the use of inferior materials or shoddy manufacturing (at least not since we expanded our QC capabilities several years ago). We're able to offer low prices because our reproduction parts don't require years of expensive R&D to develop and validate, which original equipment manufacturers must recoup in the form of high retail prices.
Have we failed to provide acceptable quality on some products over the years due to inadequate materials testing and manufacturing QC? The answer is undoubtedly yes. Have we improved in these areas and fixed many, many quality issues? I can say with 100% certainty, a resounding YES! In the last few years we have made drastic company changes and have spent a fortune revamping our product line. Today we have seven full-time mechanical and electrical engineers, a material testing laboratory, an arsenal of life-cycle and destructive testing equipment, and a complete library of OEM samples to test against.
As a company, URO cares more than you can imagine. We don't want any of our products to fail prematurely, and if there's an inherent problem causing a failure we're going to do our damndest to fix it. But at the end of the day, our standard products are for commuters who just want a good part at a low cost. For serious enthusiasts who demand the highest quality at any price, we're proud to offer the URO Premium line. Hopefully the difference will be clear to our potential customers, and whichever URO part they choose will satisfy their budget and expectations.
Again, thank you for your candid feedback. Please feel free to contact me if I can be of assistance to you or another forum member.
glhx is offline   Reply With Quote
Old 07-02-2015, 04:55 PM   #94
WDE46
I was only recommending grease for the window regulators. They are in a relatively sealed environment and won't get the opportunity to gather much grime. Any wet lubricant will get dust in it even silicone.
Btw Why are we talking about gaskets?
Old 07-02-2015, 05:15 PM   #95
jfoj
Window and DOOR gaskets, at least.
The coupes and convertibles have gaskets on the top and rear edge of the door glass, all models have door gaskets. The exterior of the window guides in sedans/wagons have a rubber outer edge, at least this is the way my E39 is configured. I need to look closely at the inside of the window guides to see if there is rubber or if it transitions quickly to the felt type of guide trim.
Also not sure if the sedans/wagons have the upper gasket with the pinch protection for the Auto Up feature?? I have to look really close at my E39.
You have to realize I have 2 convertibles, the E46 and a 2003 VW Beetle so I have a lot of rubber to deal with. Even without sticking windows, I have squeaky/itchy gaskets that need to be treated as well.
Old 07-02-2015, 05:47 PM   #96
WDE46
I thought BMW gummifledge was always the product of choice for that.
Old 07-02-2015, 06:24 PM   #97
Yewzer B Lewzer
My Ride: 2003 325i
We have been discussing the issue in the following thread:
http://forum.e46fanatics.com/showthread.php?t=1079371
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 07-23-2015, 09:59 PM   #98
akashhegde
My Ride: 2008 BMW E60 528i
One of my rear uro premium regulators went bad yesterday. Luckily still have my old one which still works. The URO Premium regulator went bad in less than 3 months.
- Akash
2002 330i (Gone)
2002 330ci (Gone)
akashhegde is offline   Reply With Quote
Old 07-27-2015, 12:39 PM   #99
akashhegde
I emailed Uro on friday and got a reply back pretty much 15 mins after I emailed in. They said that they would be more than happy to send in another window regulator on monday and that they saw my post on this thread. The person I talked to guessed exactly where my regulator failed and they are actually in the process of improving the pulley so the cable doesn't have a chance of slipping off like it did on mine.
I just got off the phone with a rep at Uro Parts and he let me know that they are sending the part in today. Overall very happy with the customer support!
- Akash
2002 330i (Gone)
2002 330ci (Gone)
Old 07-27-2015, 03:42 PM   #100
zander271
Bleh that blows...I just bought one of these. Hopefully it lasts a decent amount of time.
bmw, lifter, premium, quality, uro parts, uro premium, window regulator
