Window Desn't Drop Down Soon Enough - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 01-11-2015, 02:04 PM   #1
nbender182
My Ride: 2001 BMW M3 VERT MAN
Thumbs down Window Desn't Drop Down Soon Enough
2001 E46 M3 Very
My passenger window doesn't go down soon enough. The door needs to be opened too far before it does. The amount it goes down is fine, and it does go down every time. This is a new problem, and I'm worried it might get worse, and actually break the glass. My driver's side is fine.
Right now I can open the door slowly and notice the top of the window stays stuck into the groove until its automatically rolled down. It seems to bend the glass back an uncomfortable amount. A few months ago I replaced the regulator, but it all seemed fine then. This seemed to start about a week ago.
My searches seem to say the sensor that triggers the window to go down is a hall effects switch in the latch assembly. Is that true, and is it worth trying to clean it? Should I just replace it? I can't find the part on realoem.
nbender182 is offline   Reply With Quote
Old 01-11-2015, 03:29 PM   #2
cityjohn
My Ride: 2001 M3
Originally Posted by nbender182 View Post
a hall effects switch in the latch assembly. . . . I can't find the part on realoem.
All I can offer is that these are typically sold only as a whole unit (the latch) so you might not find part numbers for the switch inside
cityjohn is offline   Reply With Quote
Old 01-15-2015, 03:04 PM   #3
Apexeon
My Ride: drthrt
It took me a while to understand what this was about. While I don't have a solution for you, I'll reword it in case someone does have a solution
When door opened, window doesn't auto-roll down and gets "caught."
Apexeon is offline   Reply With Quote
Old 01-17-2015, 01:34 PM   #4
blueboy_gigel
My Ride: 323ci Convertible
Same thing happens to me. Bouth sides.
blueboy_gigel is offline   Reply With Quote
Old 02-01-2015, 07:34 PM   #5
scottaw
It's happened to me from being frozen. Really thought the window might break. Once it warms up it seems ok though.
scottaw is offline   Reply With Quote
Old 02-01-2015, 11:26 PM   #6
invisible man
My Ride: invisible car
The window rolls down when the handle is pulled, not when the door opens. If it doesn't move immediately, it's because there is slop in the system, and the glass is just simply falling down after the door has been opened a bit. You need to fix the slop.
invisible man is offline   Reply With Quote
adjustment, vert, window
