Old 02-27-2015, 10:40 PM   #1
Paul03
My Ride: 2002 325Ci coupe
Window Switches
My window switches have broken off, which I know is a common thing for e46's. I just don't want to dish out 50-60 dollars a switch.. does anyone know of any place where one could find them cheaper? or is 50 about as low as you'll find?
Paul03 is offline   Reply With Quote
Old 02-27-2015, 10:54 PM   #2
nepptune
My Ride: e46 330ci
You're talking about the plastic tab that you press to raise/lower the window right?
nepptune is offline   Reply With Quote
Old 02-27-2015, 10:55 PM   #3
Paul03
Yes, those damn things have all broken.
Old 02-27-2015, 11:05 PM   #4
nepptune
My Ride: e46 330ci
All 4!?
Here's what I did, I have a coupe and the windows in the back open few inches lateral, so I didn't need the function. If this applies to you, take the module out and switch it around. You will notice they're not compatible. You gonna see black little black tabs, take them out and switch them. Basically, switch the internals of each side. Not challenging at all. The only down side is that you have to lift up to lower the window down and down to lift it up. You'll get used to it lol
Old 02-28-2015, 01:13 AM   #5
Falkor
My Ride: 83 323+88m3+02 325ci
I recently had this happen to me...but i just needed to buy the flappy bit(s)
got them for $12.99 ea.
ebay item here
hint: search "BMW 3 Series E46 Window Switch Repair Button Cap Cover Replacement (Some X5 X3)"
Falkor is offline   Reply With Quote
Old 03-04-2015, 08:41 PM   #6
Paul03
ebay item here
How did you put the "flappy bits" back into the switches? my Switches work, I just need the flappy bits as well.
switches, window
