Old 03-20-2015, 09:10 PM   #1
Scarey1323
My Ride: 2001 325i
Help! 2001 325i m54b25 engine
So my car was leaking oil, gas was dripping under engine as well as making smell like gasoline in the cabin, so I changed the oil filter housing gasket, put a brand new fuel pump in, tried cleaning ccv and tunes connected with it, also put a new serpentine belt on just cause I was already in there, replaced the maf cause car wouldn't run when the old was plugged in. So after all was changed and put back together I tried starting car and it threw eml code and traction control. Also sputters for a few seconds with engine shake then the engine kills. Any help would be appreciated
Scarey1323 is offline   Reply With Quote
Old 03-20-2015, 09:21 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you put the orignal MAF back on the car for now.
Often NUBU's will connect the fuel filter wrong and there will be no fuel to the engine.
You may need to "prime" the fuel pump and purge air out of the system since you had the fuel system open. Cycling the key about 10 times to allow the pump to prime and bleed air out of the system is wise.
You may also have flood the engine if you started the engine to move the car into the garage or only for like 30 seconds. In this case you will need to hold the throttle down while cranking the engine.
See this thread - http://forum.e46fanatics.com/showthread.php?t=1069117
Old 03-21-2015, 11:44 AM   #3
Loaded325i
My Ride: bmw 325i
why would you clean the ccv?? Get a vacuum gauge and connect it to the hose going into the Brake booster line. You might have a vacuum leak. Gas was leaking by the fuel rail and u changed the pump? I'm not sure where your going with your diagnosing man. Sorry.
A mechanical hobbyist and car enthusiast
1971 Datsun 240z Devil Z red
1999 740il Titanium Silver
2004 BMW 325i CW,PP and Sports Package
1996 toyota avalon-263,000-Sold
2003 Lexus Is300-Sold
2000 Acura TL-Sold
2000 Accord 5 speed-Sold
Loaded325i is offline   Reply With Quote
Old 03-23-2015, 12:34 AM   #4
Scarey1323
My Ride: 2001 325i
Sorry new to bmw's and cars in general I meant fuel filter, figured out the problem, my throttle body plate was stuck so cleaned it up got it running, only problem is as soon as I drove it down the road started steaming from coolant spewing all over engine as well as overheating, changed the expansion tank since it was leaking but still overheating and spraying coolant, ordered a new water pump hoping it will fix. Also just learned that normal coolant isn't good for these cars so if any suggestions on what brands of coolant I should be using
Old 03-23-2015, 01:26 AM   #5
J_oH
My Ride: 2004 325ci
When it comes to your cooling system get oem. That includes coolant.
I admire your determination to fix your ride but do lots of research before tackling the job.
I'm not 100% sure but I don't think coolant would spray everywhere if the water pump was bad? I would imagine it simply wouldn't go anywhere and just overheat.
Let's hope your car wasn't in the red for long or else bye bye motor.
Good luck.
J_oH is offline   Reply With Quote
Old 03-23-2015, 01:44 AM   #6
Scarey1323
My Ride: 2001 325i
I stopped it before it hit the red, don't know what else fix. But yeah I'm trying to do my research been reading a lot. If can't get it fixed may have to take it to a shop, where I live there just isn't any good bmw mechanics or any that even will touch em
Old 03-23-2015, 02:02 AM   #7
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
How about doing a coolant pressure test when the motor is cold? As you slowly increase the pressure it should be easy to find the leak, since it won't be spraying everywhere like old faithful.
It's pretty common to do a full cooling system refresh as most of those parts have the same life span. You are lucky your overheat didn't go too far. It is really easy to overheat, blow the HG, and toast your motor.
///Mmmmmm...
Old 03-23-2015, 02:36 AM   #8
StealthLensTinting
My Ride: E46
As far as the coolant spraying and leaking everywhere and going into the red after, I had that happen awhile back, sounds like a cracked reserve tank. That's what mine turned out to be, it wouldn't hold coolant, so I couldn't drive it otherwise it'd go back into the red, hope this helps, might not be ur problem exactly but oh well.. Good luck
StealthLensTinting is offline   Reply With Quote
Old 03-23-2015, 02:49 AM   #9
Scarey1323
My Ride: 2001 325i
When you say reserve tank is that separate from the expansion tank
Old 03-23-2015, 04:33 AM   #10
StealthLensTinting
My Ride: E46
It could be the same thing I'm not entirely sure sorry
Old 03-23-2015, 04:34 AM   #11
Scarey1323
My Ride: 2001 325i
Thx for the help guys if I get it running I'll post what it was
Old 03-23-2015, 10:14 AM   #12
J_oH
My Ride: 2004 325ci
What I would do is make sure all hoses are tight, usually it's just a simple fix. Check for leaks before driving off.
When I changed my expansion tank, after I fired her up there was a leak. Turned out the upper house wasn't fully mounted. It took a lil more monkey strength to fully seat the hose, maybe only moved a cm or less but it did the trick.
Old 03-23-2015, 10:25 AM   #13
glhx
My Ride: 2002 330ci
Would change put the serpentine pulleys as well. They usually last 120k
How good is the vacuum line from the back of the intake to the fuel filter.
glhx is offline   Reply With Quote
ccv, eml, m54, maf
