///M3 Forum
Old 04-13-2015, 10:37 AM   #1
II KiiNGsLY II
My Ride: 2001 BMW M3 LSB
Exclamation Engine Shut off/Stalled at high speed
4/25/2015 Both of the camshaft sensors for the exhaust and intake have been replaced. The valve seal let oil through and onto the sensor thus causing the problem. The engine runs fine, but now the problem is that about half of the time the engine will take a while to start and turn over. I have to hold the key for about 3-5 seconds at times. Other times it will turn over right away, like normal. My mechanic isn't sure as to why this is. I think it may have something to do with the fuel pump, or fuel rail not having enough pressure at the times it takes longer. What are your thoughts?
4/13/2015 This morning I was driving on the highway at 55, I accelerated to about 70-80, then let off the gas and went to neutral. I started to change lanes when I noticed my steering was heavy, looked at the cluster and the oil and battery lights were on. While the car was moving I started it and went on my way for another mile. I have done some research and found this forum:
http://www.m3forum.net/m3forum/showthread.php?t=334073
I have a K&N air intake with the cone shaped filter. I do not know if the certain part is there that seemed to fix the problem. If it is not there, will this fix the problem?
This is the first this has happened.
I have a 6 speed manual
INSTAGRAM: ticktockdock
2001 M3 LSB 6 Speed
My M3 Thread
HERE
II KiiNGsLY II is offline   Reply With Quote
Old 04-13-2015, 12:22 PM   #2
TboneM3
My Ride: E46 M3
These are the exact symptoms I had when my fuel pump first started to fail. It couldn't pump fuel at high demand and the car died. Your oil and battery lights were on because they're always on when you turn the key to accessory power (before you crank it). They weren't on because there was a problem with oil or alternator.
I suppose it could be the K&N air filter. I'm not a fan of aftermarket air intakes (besides CSL reps) and since they aren't better than stock (our stock intakes are massive and very well designed), I can't see the point in having one. I would clean your maf and put the stock intake system and filter in.
///2004 SilberGrau M3 Coupe 6MT no sunroof/zero options
Evolve-R eVenturi Euro Headers|Sect 1 OE CSL OM Scorza D/A pullies/fan delete TMS camber/subf plates
RE Besian AKG AutoSolutions 30% TMS front sway GroundControl(Koni/Eibach) Sportline 8S 18" PSS 245/275
TboneM3 is offline   Reply With Quote
Old 04-13-2015, 08:02 PM   #3
Hobohunter
My Ride: 2001 M3
Mine would periodically shut off at idle or slowing down to stop at a stop sign. The PO had built a home made intake with an aluminum tube and a K&N cone filter. I replaced it with a full OEM setup I found on Ebay. Hasn't done it since. I would recommend just getting rid of the cone filter and using the stock box.
Hobohunter is offline   Reply With Quote
Old 04-14-2015, 07:53 AM   #4
II KiiNGsLY II
UPDATE: my service engine soon light came on this morning. Nothing happened while driving, just a regular drive.
I was messing around with the left instrument cluster button, could I have changed the service interval by accident? Or is this a situation that needs to be taken to the shop?
I plan on replacing the K&N air intake with the OEM one soon, maybe this the the source of the problem.
2001 M3 LSB 6 Speed
My M3 Thread
HERE
Old 04-14-2015, 08:10 AM   #5
syl3ntforce
My Ride: E46 M3
Send a message via AIM to syl3ntforce
I have heard a few issues with K&n intake systems, that it will not let you turn on the car and the car will shut off and you lose power. I had a k&n CAI and it was good nice noise and look but the low end power was lost a bit and car shut off on me a few times went back to oem an car runs perfect hasn't shut off on me throttle feels better i am looking into the gruppe M intakes though now or at least some intake that comes with a box(heatcover)
-Paul
318i>328i>328i>EK Civic SI>328ci>328xi>E46 M3
syl3ntforce is offline   Reply With Quote
Old 04-14-2015, 03:22 PM   #6
II KiiNGsLY II
UPDATE: I was able to run the codes and got P0014, and P0017. I know that they deal with the camshaft sensor, and have one ordered. I have also bought an OEM air box with MAF, but I wont change it right away, just to see if the new sensor solves the problem. If it doesn't, which it should, then I will replace the K&N. Thank you for all the input thus far!
2001 M3 LSB 6 Speed
My M3 Thread
HERE
Old 04-30-2015, 06:17 AM   #7
II KiiNGsLY II
Bump, new update and issue at the top.
2001 M3 LSB 6 Speed
My M3 Thread
HERE
Old 04-30-2015, 08:19 AM   #8
DSilk56
My Ride: M-3 Convertible
The service interval advisory on your odometer is not affected at all by the buttons/knobs on either side of the cluster. It is reset via the OBD connecter located behind the access panel on the left lower panel next to the steering column (and needs to be hooked up to an external reader for a reset). The SES light means that something about the operation of the engine or emissions system is out of spec. It could be something major (but you would feel it in the way the car runs) or could be failing or defective O2 sensors or catalysts. Read the codes to find out what the problem is.
DSilk56 is offline   Reply With Quote
Old 06-13-2015, 09:05 AM   #9
II KiiNGsLY II
Update: After the last update the engine still had the occasional double start. I went on a road trip with no codes. About 300 miles in my SES light came on. It was the last day of the trip, so I could bring it straight home afterward. Turns out it is P0014 and P0017 camshaft codes again. Went to my mechanic and the readings seemed fine. So then I went to BMW and got the airbag recall and an hour of diagnostics done. He said it needed new CPS's, but then I told them they were new, and that during the first run around with the CPS we did a VANOS bolt replacement. He did the vanos timing test multiple times and nothing threw a flag. He came to the idea the engine just needs to be re timed. Any thoughts or insight into this new diagnosis? Need some help here!
2001 M3 LSB 6 Speed
My M3 Thread
HERE
Old 06-13-2015, 12:46 PM   #10
Cayne23
My Ride: 2002 m3 convertible
I had intermittent start problems. I would crank and no start. Stop, try again. Starts immediately. One day after i got off of i95, while sitting at a red light my car just died. Towed to my shop. It needed a new fuel pump
Cayne23 is offline   Reply With Quote
Old 06-13-2015, 12:47 PM   #11
Cayne23
Also, the p0014 code is an exhaust timing over retarted code. Check your timing.
Old 08-08-2015, 09:19 PM   #12
II KiiNGsLY II
Update Solution:
As seen above and suggested by the BMW Tech, the engine needed to be retimed. My mechanic missed a step when re assembling the vanos sprocket which caused the engine to run out of sync. The double start issueis resolved, among the feel, sound, and performance has all improved.
2001 M3 LSB 6 Speed
My M3 Thread
HERE
air intake, engine, help me, problem, stall
