Old 05-04-2015, 04:50 PM   #1
datadrian
My Ride: 2005 325i wagon
Question Trying to locate bluetooth module on 2005 bmw 325i wagon
Looking for the ULF module so I can obtain the bluetooth pairing code. I've pretty much been through all the spots decribed that it may be in the trunk. Even done some exploration on the right side of the trunk. All the car forums deal with the non wagon version. Took it to the dealership and they didn't know where it was. They wanted to charge 260 to read the computer. All the forums make it looks so easy! Thanks!!
datadrian is offline   Reply With Quote
Old 05-04-2015, 06:54 PM   #2
eneka
My Ride: 2003 325i
it's in the upper right corner of this picture behind the felt. Peel it back it's it'll be there. Don't worry, you're not the first one to have trouble finding it.
Peel back the upper right corner of felt You should then see three studs coming from the back side of the body support panel. These studs are from the black ULF bracket shown in the instructins that you found. Behind the black bracket is the silver ULF. Those three studs should confirm the location of the ULF on your '05.
http://www.bimmerboard.com/forums/posts/400331
eneka is offline   Reply With Quote
Old 05-04-2015, 07:02 PM   #3
datadrian
Yess!
You are amazing. It was back there all along! Thank you thank you thank you! You've got a few free drinks in Los Angeles!
blue tooth, bluetooth
