Sponsored by BAVSOUND
Old 06-04-2015, 01:20 AM   #1
Hamretro
My Ride: 2005 BMW 320ci E46
mediabridge bluetooth
I have the bmw business cd radio and for some reason it will no longer detect mediabridge so I can't pair my phone with bluetooth. If I select "mode" and scroll to bluetooth it will display "BT" and then shortly after "OFF"
It use to say "mediabridge" -> "phone connected" I managed to pair it up when I first bought the car but now it won't even find mediabridge.
Any suggestions?
Hamretro is offline   Reply With Quote
Old 06-04-2015, 08:56 AM   #2
markusmarkus
My Ride: 2001 330Ci
Are you having any other electronix issues. Does the head unit work properly otherwise? Can you reset the mediabridge?
Old 06-04-2015, 09:38 AM   #3
dmarkle
My Ride: 2002 330Ci
Unplug and reconnect the Mediabridge. It should reset itself.
dmarkle is offline   Reply With Quote
Old 06-06-2015, 03:27 AM   #4
Hamretro
Okay was on the lines of doing that but was hoping it was just gunna be messing around with some buttons... just gotta find out where unit is installed -.-
Old 06-06-2015, 05:12 AM   #5
BritsAbroad
My Ride: 2002 M3 vert
I just installed my mediabridge. Phone is connected via Bluetooth, iPod interface works. How do I change modes so that I can play via Bluetooth or AUX? I have a single din radio.
BritsAbroad is offline   Reply With Quote
Old 06-06-2015, 06:34 AM   #6
davidmaria1
My Ride: 2001 330i
Pull the left (drivers) side trim in the trunk, that's the most common spot.
I installed a mediabridge a couple months ago. It's just ok, the sound quality is not great, sometimes an incoming call won't pickup when pressing the up button and I've never been able to get the usb cord to work, just Bluetooth. Then again, I have the patience of a 3 year old.
THINGS I'VE DONE: Cooling system refresh with radiator, key fob surgery, K&N filter (removed), pulleys belts and tensioners, ECSTuning aluminum w/p pulley, CCV cold weather, DISA gasket, OFHG, Fuel pump/filter PM, ZF auto trans fluid/filter, motor mounts, fcabs, 2nd trans fluid change, steering giubo, rear wheel bearings, rear swaybar links
davidmaria1 is offline   Reply With Quote
Old 06-07-2015, 07:43 PM   #7
Hamretro
Reset the Mediabridge unit and still no fix. The MB unit was wedged into the plastic bracket behind the glove box and the usb and the 3pin connector were pretty badly bent from a very careless install. Not happy :/
Old 06-24-2015, 01:12 PM   #8
rjsquire
My Ride: 2006 330Ci Conv
You can only change mediabridge modes within the first 5 seconds ( i think ) of selecting it on the radio. So, go to FM mode, then hit the mode button until the mediabridge displays "USB", then (within 5 seconds) hit the right or left arrow buttons to switch to bluetooth, aux, or sirius (if you have it). Hope this helps.
rjsquire is offline   Reply With Quote
bluetooth, connecting, mediabridge
