Old 06-17-2015, 04:39 PM   #1
Davidcarter
My Ride: 318ci msport
OVERHEATING 318ci
I'm new here and to BMW please go easy on me
So I'll get straight to the point (kind of) I brought a 318ci, gorgeous car, the other day went to inspect it as you do gave it a good test drive seemed all ok no problems whatsoever ever other than a slow puncture 120,000 miles that day I drove it all they way back from where I brought it home a good 120 miles and a good few hours drive
The next day I start it up wasn't going to drive it just started it up sat inside fiddling about with the stereo and what have you when I look up the temp needle was in the bright red and there is white smoke pooring out instantly switched the engine off, jumped out and saw all if not most of the coolent on the floor
When it had cooled a few hours I started it back up just to put it into the driveway and it got hot pretty quick (no coolent obviously) I was just wondering what could of happened I guessed to just fill or flush making sure there is no leaks, however when I opened the coolent tank a little later it was a tiny bit foamy i would have thought air should have came in when the coolent came out. The next thing I did was check my oil by opening the cap it was black no creaminess what so ever don't think I could have a blown head gasket and still be driven home 100+ miles could it?
Not having a BMW before I have no I sea what could have caused it or what I should do , that's why I need your help
Thanks sorry it's so long tried to be as descriptive as possible
Davidcarter is offline   Reply With Quote
Old 06-17-2015, 04:42 PM   #2
clabcon
My Ride: e46 330 Ci
Mango has a sticky covering the E46 cooling system at the top of this forum.
clabcon is offline   Reply With Quote
Old 06-17-2015, 05:12 PM   #3
Mario0617
My Ride: 2003 330i
You have some part in your cooling system failing. My bet is Expansion Tank or Water Pump. I don't know much about the 318 engine, but it's probably a bit better than the M54 in terms of overheat resistance. First things first, you need to figure out what's busted in there. If you suspect a blown HG, get a compression test done prior to spending any more money.
Mario0617 is offline   Reply With Quote
Old 06-17-2015, 05:30 PM   #4
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You overheated your car and may have damaged the head gasket and/or head.
Need to put some water in and see where it pours out.
The foam in your expansion tank is oil mixed in with the water.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 06-17-2015, 07:41 PM   #5
Davidcarter
Thanks man don't know how I missed that overheating thing will do both compression test and put water through the system I'll reply with the outcome
Old 06-19-2015, 12:43 PM   #6
Davidcarter
Compression tester hasn't come yet but now have oil in my coolent and coolent in my oil :/ thats just great
Old 06-19-2015, 06:32 PM   #7
BMWCaptain
Clear signs of a bad head gasket.
BMWCaptainE46.com
318ci, coolant, help a noob, overheating
