Leaking coolant front centre, dripping from fan - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-21-2015, 08:54 AM   #21
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If you don't change the cooling system which is already showing neglect and problems then don't drive it because it will eventually fail you and leave you on the side of the road. BMW's are not cars that you can just put gas and go because driving the car to the ground will result in more problems (overheated/cracked heads, etc). They need preventative maintenance such as the cooling system (everyone knows BMWs have weak systems), fuel pumps need to be changed over 100K miles because they will give starting issues and more.
Old 06-21-2015, 08:56 AM   #22
chmac
My Ride: 325i
OK, thanks again @Solidjake.
I'll call some places tomorrow and get a quote to replace the radiator and the whole cooling system. Once I have some prices, I'll make a decision and post back how I get on. :-)
Really appreciate all the help folks.
chmac is offline   Reply With Quote
Old 06-21-2015, 09:07 AM   #23
Solidjake
Zero. Leaks.
Solidjake's Avatar
Cost for all of the parts is around $500 USD including the radiator. - radiator (behr), bmw coolant, water pump (Saleri, Geba, Graf), water pump pulley, thermostat (walher), expansion tank (oem), expansion tank cap (oem), coolant level sensor, lower radiator hose, lower radiator hose sensor, upper radiator hose
Old 06-21-2015, 06:44 PM   #24
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Gotta agree with Jake. If you were planning on scrapping the car I'd say go ahead and use something like a a Barrs Stop Leak - but it will cause irepairrable damage to other aspects of your car (permanently slows & clogs flow of the heater core).
So the best route is replace the radiator and if you can afford to replace the other major cooling components Jake mentioned. At least you know what it is now that's leaking. Nissens or Behr make a good rad for this car.
BTW - if you were able to remove the fan - it's really not very compex to replace all the components Jake listed. No special tools needed for the manual tranny cooling system. There are plenty of detailed DIY's around here to guide you through it. Good luck.
BMW-North is offline   Reply With Quote
Old 06-25-2015, 06:23 AM   #25
chmac
My Ride: 325i
Thanks for all the help folks. I got the radiator replaced yesterday. Filled with fresh coolant. Total cost was about 190 and took most of the day, but it's done, and that's the main thing! :-)
Really appreciate all the feedback and input here, made the whole diagnosis and resolution process 10x easier at least.
325i 2001, coolant leak, help a noob
