2003 325i MAF urgent help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-29-2015, 06:43 PM   #1
xDecrypted
My Ride: 2003 BMW 325i
I'm new to the forums I tried searching but no luck. A little help please my MAF may be going bad but don't know. Coming to a stop my cars rpm will go up and down between 500 and 1k rev. Sometimes when I hit the gas it shuts off I unplugged the MAF and seems to be okay then I plug it in and the car dies.
Since it dies is it going bad ?
xDecrypted is offline   Reply With Quote
Old 07-29-2015, 07:24 PM   #2
xDecrypted
Bump
Old 07-29-2015, 09:02 PM   #3
djacs1
My Ride: 2001 325i
Search more, there's a lot of threads here about this kind of engine problems (rough idle, swinging rpm, stall). This may not be your MAF.
Try jfoj thread:
http://forum.e46fanatics.com/showthread.php?t=897616
Good Luck
djacs1 is offline   Reply With Quote
Old 07-29-2015, 09:26 PM   #4
Stinger9
My Ride: '04 330Ci
cleaned throttle body and ICV?
checked for air leaks?
Old 07-29-2015, 09:42 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Its not likely the MAF. I assume the SES/CEL/MIL is on, if not you have another problem to address.
Check codes, Freeze Frame and Fuel Trim info and report back.
2 words, Vacuum Leaks!
Old 07-30-2015, 10:51 PM   #6
xDecrypted
Seems like it might be the MAF sensor as I unplugged it, drove around and it didn't seem to rev between 500 and 1k anymore. Didn't see vacuum leaks. Will check more throughly and also seems that my PCV crankcase needs to be changed black smoke came out from the exhaust when reving it up. Any idea ? It's burned my oil up
Old 07-30-2015, 10:54 PM   #7
jfoj
Well, you need to understand a few things here.
1. Unplugging the MAF puts the engines fuel Map into a default mode that is slightly Rich which will cover up/mask Lean problems.
2. If you had an OBDII scan tool that supported Live/Realtime Data, you could monitor the MAF reading and Fuel Trim values and figure out what is going on.
You can choose to replace the MAF, but this is not likely the primary cause of your problems.
Old 07-31-2015, 12:11 AM   #8
xDecrypted
Also could be disa valve as I hear rattling in there.
Any idea about the black smoke and burned up oil
Old 07-31-2015, 02:00 AM   #9
NumbaOneNewb
My Ride: 2003 330CI Silver
Could be the entire engine. We can guess all day long but if you want a pin point answer, researching and investigating is needed
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 07-31-2015, 09:37 AM   #10
jfoj
Not likely the MAF as I stated.
DISA's are problems, they do not last forever and can cause Lean problems, idle issues and stalling. BUT so do MANY other things on these engines like intake boots and CCV and CCV hoses.
Black smoke can be due to these or a cool running engine.
What you need to do is gather DATA with an OBDII smart phone App.
Need to see Logs for engine, DTC's (trouble codes), Freeze Frame and Live/Realtime data for MAF, Fuel Trims and O2 sensors.
Get an OBDII smart phone/tablet App and interface, typically $30 or less. These Apps are usually best for drivability issues and they support Emission Readiness Monitor Status, Freeze Frame and Live/Realtime data. They are also great for Logging data for review after the car has been driven and can really help find unusual problems.
Android - Touch Scan for $3.95 and ELM327 OBDII to Bluetooth interface.
iProduct - OBD Fusion for $9.95 and ELM327 OBDII to Wifi interface.
I usually suggest getting the OBDII interfaces from Amazon if you are located in the US/North America. Make sure you choose an interface that indicates that the order will be "Fulfilled by Amazon" otherwise you may be waiting for WEEKS for an interface to arrive from Asia. Ebay is another option, but pay attention where the interface will be shipped from, again weeks for an interface from Asia, so if you can wait and want to try to save some money, go for it, but if you need an interface soon, choose wisely.
idle, maf, mass air flow sensor
