Old 08-05-2015, 02:40 PM   #21
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
You said another cooling component blew out last week. It would be prudent to find out why cooling components are exploding. The cap on your ET is designed to relieve pressure to avoid this type of event - it would be wise to change that also. Granted plastic parts can fail due to age & fatigue from excessive heat cycles but more often than not there is an underlying cause. If your car was well maintained with correct cooling PM this should concern you even more. As I stated your electric fan works on 15 speed requests from the DME. When 1 or more of these requested speeds fails it is very difficult to diagnose - you are experiencing the classic symptoms (exploding parts at idle).
How old is your electric fan unit? If it is original it really should be tested since you have a manual and it is the only method of moving air at an idle.
The method above suggesting if your car holds temp at idle does little. You have a heavily buffered temp gauge (40C range). If you start from cold and just idle till it gets to 12 o' clock the temp may actually be climbing but the needle will not show any movement as it does not move to the right till the temp is severely high - then it jumps. Many e46 owners have used a software program (PA Soft - Ebay $25) to reduce or eliminate the temp gauge "normal buffer" so that any increase in temps is reflected immediately by a moving needle. I would recommend you look to doing this - it's free - just needs knowledge and the right tool.
http://forum.e46fanatics.com/showthread.php?t=1013600
If you really want to monitor this after you replace the ET use the hidden OBC function 7 which will show a digital display of the actual coolant temp in real time - this way you can see it increase although the needle is not moving.
http://forum.e46fanatics.com/showthread.php?t=239619
Finally take the car for a spirited drive of at least 30 mins with nice high revs then get back to your home and idle - while idling at this point watch the temp gauge and the OBC temps - if the problem still exists - this is when you will see the temp climb. During idling bit put the AC ON then after 2 mins turn it off - watch the temp and the electric fan reaction. If you idle for at least 7-10 mins without any concern you should be ok. If you read my posts on here about this fan, going back many years, I have noted however that it can fail intermittently - the reduced temp buffer would be a good idea for future overheat prevention. If you get by Orangeville anytime PM me and I'll test it for you and remove the temp buffer.
BMW-North is offline   Reply With Quote
Old 08-05-2015, 03:35 PM   #22
kdoubt
My Ride: 330i
Once I get it back I'll definitely be keeping a close eye on it. Trying to prepare it for sale in the best possible condition.
kdoubt is offline   Reply With Quote
Old 08-05-2015, 05:20 PM   #23
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
who the f puts parts on the paint to take a pic?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 08-05-2015, 05:39 PM   #24
kdoubt
My Ride: 330i
My mechanic on his own car. Thats who the f.
Old 08-05-2015, 05:56 PM   #25
wasp9166
problem?
eh, nm, this thread makes it clear it would be a waste of my time
good luck
Old 08-05-2015, 06:21 PM   #26
kdoubt
My Ride: 330i
problem?
good luck
You asked who, I told you with your own language. Thanks for your invaluable input "buddy".
Old 08-05-2015, 06:24 PM   #27
Zell
Zell's Avatar
My Ride: so turbo wow
He's not your buddy, guy
Old 08-05-2015, 06:24 PM   #28
kdoubt
My Ride: 330i
Glad you caught that
Old 08-05-2015, 07:40 PM   #29
wasp9166
owns a bmw and has no idea what's going on when he see's a river of coolant, comes on forum and proceeds to act smug , a mechanic that photo's parts on his own car sure as sheet doesn't care about his car , so why would he care about yours?
get a new mechanic , better yet , get a diff car and a diff attitude
and btw, you're in ontario, don't pretend to speak the lang of someone from the bronx, esp on the internet
have a great night aquaman
post count, 5,800
post count 5,800
post count 124
i know, i'll be a smart azz to both of em
good job
Old 08-05-2015, 07:45 PM   #30
Zell
Zell's Avatar
With a location of Ontario, I couldn't not
Old 08-05-2015, 07:57 PM   #31
kdoubt
My Ride: 330i
330i, coolant, e46, leak, reservoir
