Old 08-27-2015, 08:51 PM   #1
Viicariious
My Ride: 01 BMW 330ci
Manual conversion e46 330ci Drive shaft to diff problem
So im doing a manual conversion on my e46 330ci. everything is up and in except the drive shaft. I went and pulled a manual drive shaft from the junkyard in hopes i could use the rear of the auto shaft and the front of the manual shaft as many others have done. but the problem i encountered was that the rear of the auto shaft was a male end and the front of my manual shaft was male as well. After seeing that i tried to just pop in the complete manual shaft but the input flange on the differential has 6 bolt holes and the shaft only has 4... I really dont want to fork out 700$ on a new shaft. I was thinking of swapping the U joints of the auto and manual shafts so that it will fit but im not too sure if BMW u joints are even replaceable. Another idea i had would be to swap a manual diff flange onto my auto but im not entirely sure if it will work.. any help or input would be nice. TYIA
Viicariious is offline   Reply With Quote
Old 08-28-2015, 08:13 AM   #2
markusmarkus
My Ride: 2001 330Ci
Try a driveshaft repair service. I'm sure there's one in your part of western NY.
differential flange, driveshaft, e46 330ci, help a noob, manual swap
