Power Steering pump beggining to fail? Help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-06-2015, 11:59 AM   #1
Tre325
My Ride: 03 325i
So I have run into a problem and from what I researched it leads me to believe my power steering pump may have failed on me. I have searched the forums but haven't seen or read anything quite like this. The steering is not stiff & the noise occurs whether I'm driving or at a stop. This is a link to a video of what I am dealing with. The knocking sound occurs when I slightly turn the wheel to the left or right. My fluid is topped off also
Tre325 is offline   Reply With Quote
Old 10-06-2015, 12:20 PM   #2
kdp8604
My Ride: 04 325i
Have you checked your pulleys. My power steering pump shaft broke and I didn't have noise like. I hear almost a knocking sound. Does the sound get louder when you turn.
kdp8604 is offline   Reply With Quote
Old 10-06-2015, 12:30 PM   #3
Tre325
My Ride: 03 325i
Yes as I turn the wheel the knocking gets louder turning left or right. From what I can see the pulleys are running fine but I haven't yet taken anything apart to see if there's any play in the pulleys. My time is limited as I have to go to work and pull 12 hour shifts all week and school until this weekend. My next step will be taking everything apart.
Old 10-06-2015, 12:51 PM   #4
kdp8604
My Ride: 04 325i
Get your belt off and check pulleys if the shaft broke on water pump it will come right out of the front of the pump with ease.
Old 10-06-2015, 01:54 PM   #5
Tre325
My Ride: 03 325i
Thanks, I appreciate you pointing me in the right direction before I take it to a mechanic. I'll look to take the belt off when I get off in the a.m.
Old 12-03-2015, 12:59 PM   #6
ssmith9867
My Ride: 01 330CI
So what was the outcome? I developed the exact same noise two nights ago. Literally exact same as in the video. 01 330CI
ssmith9867 is offline   Reply With Quote
Old 12-03-2015, 01:34 PM   #7
Knight
My Ride: '05 330Ci | '01 325i
Did you check your PS fluid levels?
I had a different noise shortly before my PS pump failed. Figured it was a pulley and a few days later the pump completely died (shaft broke and could be pulled straight out).
Knight is offline   Reply With Quote
Old 12-03-2015, 03:16 PM   #8
orb
My Ride: 325Ci
when the shaft breaks does this throw the belt?
orb is offline   Reply With Quote
Old 12-03-2015, 03:20 PM   #9
Knight
Mine didn't throw the belt. PS assist in the car failed while parallel parking in NYC. Drove the car home at the end of the night and put it up on jack stands. The belt and PS pulley were still in place.
After loosening the bolts, when I went to pull the pulley the entire shaft came right out.
power steering, power steering pump
