No start problems, new EWS maybe bad DME?? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-19-2015, 04:52 PM   #1
SabrinaB
My Ride: E46 330i
I've recently started having issues with a bunch of things needing to be replaced but now I'm having no start issues with my e46 330i.
I got it to work for about a week after replacing my EWS and getting a new key programmed to it but the other day when I went to start it would crank but it wouldn't start up.
I know it's not my fuel filter or pump, battery or my starter so I guess I'm lost. The guy that programmed the ews and key to my car said he needed to redo it because it deleted the code, how is that a thing?!
Do I need to reprogram my DME, buy a new one or could it be something else completely? I'm still learning as I go so a little help would be great!!
SabrinaB is offline   Reply With Quote
Old 11-20-2015, 12:49 AM   #2
daniel_f.
My Ride: 330iC
First of all we need to find out if your car is equipped with MS45 or MS43. Could you take out the DME in the engine compartment and take a sot of the labels on top of it?
Old 11-20-2015, 12:03 PM   #3
SabrinaB
My Ride: E46 330i
Ok, so I just opened it up and I have an MS43 DME.
Is it a normal issue to delete key code memory or something?
Old 11-20-2015, 01:06 PM   #4
daniel_f.
My Ride: 330iC
So as you have a MS43, you can easily flash your ecu with ews delete software to test if it does the trick.
If so, you can either use it like that or purchase a used DME and virginize it to match it to your ews unit.
The latter is ~50$ for a used part and another 20$ for an obd interface.
Head over to the general section of this forum and search for MS43 ews delete
Old 11-20-2015, 01:11 PM   #5
SabrinaB
My Ride: E46 330i
Thank you!!!
And if that doesn't do the trick I can pretty much deduce that it's not my DME altogether, yeah?
Old 11-20-2015, 01:52 PM   #6
HakenTT
My Ride: 323i with S54
Problem is MS43 will go out of sync with EWS module, electronics are getting old and this will become more common. I sell already flashed MS43 with removed EWS block so it will work all the time. Contact me via PM
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
dme relay, ews delete, help a noob, no start issue
