E46 Xi Forum
Old 11-30-2015, 10:32 PM   #1
smalltwig
My Ride: 2003 330XI
2003 XI sounds like a circular saw on metal
Video below. From what I've read (great guide on noises btw!), seems like a pulley? Just wanted confirmation that it is in fact safe(ish) to drive until I can swap out the pulleys.
Also, you might notice a ticking sound in the video as well. I'm hoping it's just my spark plugs needing to be tightened. But any info on that would be super appreciated.
That horrible saw sound started with the colder weather. Was mild at first, I thought it was just something to do with the intake at first. (today it got worse...much worse)
The ticking has been around for a while, usually would go away after about 10 - 30 seconds at idle or a quick rev. Lately it's been lingering around longer and getting louder. An oil change seemed to help (back to how it sounded 8 months ago).
Also, a PSA : Had my oil changed at Pepboys last, $99 full synthetic "deal". After 5,000 miles, I got just a bit over 3 quarts out (did it myself this time, usually i get around 5-6) of ink. Never noticed any leaking oil. And I've sure as hell never seen anything like this after a mere 5k miles. I wouldn't recommend them (they assured me they filled it with 6.5 quarts... I don't think so).
Looked a lot like this (5k miles). Note: Not my photo, found on Bimmerfest.
http://i1098.photobucket.com/albums/g376/matthew_henson/IMG_7172.jpg
smalltwig is offline   Reply With Quote
Old 12-01-2015, 09:20 AM   #2
latitude39
My Ride: 2002 325xi (163k)
Originally Posted by smalltwig View Post
... confirmation that it is ... pulleys.
... ticking sound ... it's just my spark plugs needing to be tightened.
... oil changed ... I got just a bit over 3 quarts out (did it myself this time, usually i get around 5-6) of ink. ...
Pulleys: You can use a long screw driver set near the non spinning base of the pulley and your ear on the handle to confirm for yourself. A mechanic's stethoscope is better.
I doubt that "loose" spark plugs are the source of the ticking, which I couldn't hear over the buzzsaw.
Oil: Its a good idea to pull the dipstick after an oil change. My wife drove out of an oil change place and immediately noticed a "red light" (oil pressure) on the dashboard. She drove it (Honda Accord) right back. They had forgotten to put oil back in. Car ran 10's of thousands of miles longer without issue though.
With such low oil level you should have gotten a yellow oil level light. ??
latitude39 is offline   Reply With Quote
Old 12-01-2015, 09:30 AM   #3
smalltwig
My Ride: 2003 330XI
Thanks, yeah I'll try checking with the stethoscope.
And as far as that "yellow" light goes, it's always turned on right at the start. Even after a manual oil change.
Old 12-01-2015, 10:28 AM   #4
zander271
My Ride: 6spd ZHP/5sp XI
Sounds like a faulty oil sensor. When it is faulty the yellow oil light turns on when you start the car for 15 seconds and then goes off.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 12-01-2015, 06:25 PM   #5
smalltwig
My Ride: 2003 330XI
Huh, good to know. Will take a look this weekend.
Old 12-01-2015, 09:12 PM   #6
qweqwertyuiopasd
My Ride: qweqwertyuiopasdfghj
Gt-s7582
qweqwertyuiopasd is offline   Reply With Quote
Old 12-01-2015, 09:17 PM   #7
qweqwertyuiopasd
GT-S7582
Old 12-01-2015, 09:19 PM   #8
qweqwertyuiopasd
Gt-s7582
Old 12-01-2015, 09:19 PM   #9
qweqwertyuiopasd
[img][/img]
gt-s7582
Old 12-01-2015, 09:25 PM   #10
qweqwertyuiopasd
http://<a href="http://<a href="http...;/IMG]</a></a>Attachment 618946
Originally Posted by qweqwertyuiopasd View Post
Gt-s7582
GT-S7582
Old 12-01-2015, 09:40 PM   #11
qweqwertyuiopasd
gt-s7582
gt-s7582
Old 12-01-2015, 09:44 PM   #12
qweqwertyuiopasd
[img][/img]
gt-s7582
gt-s7582
gt-s7582
Old 12-02-2015, 12:48 AM   #13
qweqwertyuiopasd
gt-s7582
gt-s7582
Old 12-16-2015, 09:24 PM   #14
jmo69
My Ride: 03 325xi 98 328is
I think you need to pull the dipstick a little more often, my M54 can go 7500 miles with little to no drop in oil level but I still check at least once a week. Some of these cars will use a qt in 500 miles. Pull the serpentine belt and check for play in the pulleys and for excessive wear on the belt or spray some belt dressing on it when it's squealing to see if it goes away temporarily.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
e46, engine, scream, sound, whine
