Sponsored by BimmerWorld
Old 12-03-2015, 10:48 PM   #1
maynardflies
My Ride: 04 330Ci convertible
Can I reuse some almost new Meyle HD FCABs?
Hi Fanatics,
I recently bought myself some Meyle HD control arms for my 2004 330ci vert, and to save a few bucks I got ones without bushings pressed on, because the bushings were replaced when I bought the vehicle a couple years ago
The bushes are pretty much new, and if possible I'd like to reuse them, but I see a lot of people saying you can't reuse the OEM ones, and that you CAN reuse the Urethane ones.
What about the Meyle HD CABs? Can I reuse them? Any tricks to make sure they are reusable when I remove them?
Thanks a bunch!
maynardflies is offline   Reply With Quote
Old 12-03-2015, 10:53 PM   #2
cvx5832
My Ride: 325Ci, 325Cic, C300
Puller plate in conjunction with a puller. If you just use a puller you can rip them because they'll be fused to the arm by now.
Personally I'd just replace them. They're inexpensive and very much a wear item on the E46. Might as well reset the clock since you have it out.
Last, can you post a link where the bushing is pressed into the arm? When did that become a thing?
cvx5832 is offline   Reply With Quote
Old 12-03-2015, 11:14 PM   #3
maynardflies
Maybe I'm saying it wrong. When I look at arms on eBay all the pictures have the bushings and carriers already on the arm. Thanks for the info!
Old 12-05-2015, 12:06 PM   #4
maynardflies
Well unfortunately my hand's being forced. My CA joints are getting bad and it's getting colder up here in the Great White North, which means I really need to get these CA's changed this weekend. That means no time to order new CABs or a puller plate as I'm realizing that's not something I can just buy at Crappy Tire (our local auto parts mega-store)
Any tips on getting the Meyle CABs off in one, reusable piece with normal tools?
Old 12-05-2015, 01:28 PM   #5
atgatt
My Ride: 2003 BMW 325xi
Without the correct tool this will be a challenge.
atgatt is offline   Reply With Quote
Old 06-28-2016, 11:12 PM   #6
maynardflies
Late thread update! I ended up fashioning a rig to hold the center of the CABs while pulling them with a gear puller and they came off quite easily, and went on with a little soap to the new arms with no issues. Car rides like it's on rails again!
control arms, diy, fcab, meyle, suspension
