Sponsored by BimmerWorld
Old 01-06-2016, 01:03 PM   #1
kbeaud
My Ride: 2002 330Ci
330Ci Upgrade
Hi everyone! Right now I have the stock suspension for my 02' 330Ci. I am looking to purchase the suspension of a parted out 04' M3 (It's front and rear OEM with 8K miles on it for $100). Is this a straight swap or will some fabrication be needed?
kbeaud is offline   Reply With Quote
Old 01-06-2016, 02:45 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
The answer was at the top of this page had you just looked.....
http://forum.e46fanatics.com/showthread.php?t=965693
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 01-06-2016, 03:40 PM   #3
kbeaud
My Ride: 2002 330Ci
Thanks Rob, I did not see that prior and it does a comprehensive job of explaining it is not worth the effort. So, does anyone have any ideas of worthwhile upgrades to the suspension that I can do?
330ci, suspension, upgrade
