Old 02-15-2016, 05:45 PM   #1
iowna330xi
My Ride: is not yet fast.
M52 Intake Manifold Removal?
Hey guys, would it be worth it to remove my intake manifold during the winter? I have a coolant leak right under it, and Im pretty certain its coming from the heater hoses. I already have the o rings for the hoses, but I still need to order the manifold gasket. How many hours approx. did it take for you guys to remove and install the manifold? Ill be working in the garage in around 37 degree (F) weather.
iowna330xi is online now   Reply With Quote
Old 02-15-2016, 09:14 PM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It takes about 6 to 8 hours the first time. Quicker the more times you do it.
You need the hard water pipes under the intake. They get brittle and leak.
You want to replace the hard water pipes, the CVV, intake manifold gasket, intake boots, and small vacuum hoses.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-29-2016, 10:59 PM   #3
iowna330xi
Okay, thanks for the info. I finally went through with it, and I replaced the coolant heater hose. No more leaks! Now i can finally switch to bmw coolant just for the "originality" effect. Im able to remove the manifold in less than an hour now, after having to remove it repeatedly.
coolant, intake manifold, manifold
