Old 03-10-2016, 12:49 AM   #1
gslother
My Ride: 2005 330i ZHP
2005 e46 zhp ticking help!!!
Aloha, I know there are several threads on here as well as other sites about this issue with this engine. They do not contain any answers!
Vehicle: 2005 330i ZHP 48,000 miles
Problem: I have ticking noise that comes once the vehicle gets to normal operating temp. On cold starts the engine is super smooth and quiet. Once it gets warm it starts and is consistent. It does not go away.
I have replaced spark plugs, pullys, new belt. Cam position sensors and I even had all the lifters replaced with brand new ones. The timing chain guide is good condition.
I am pulling P171 and P174 codes but don't believe that a vaccume leak would generate this type of noise. I am going to check this weekend for the leak.
Below is the video with the sound. This noise is driving me crazy. Thanks for the help!
_a_
gslother is offline   Reply With Quote
Old 03-11-2016, 01:44 PM   #2
bimmernut3
My Ride: '05 330cic, '01 540i
I too have a '05 330Cic ZHP (convertible) with 54k on the odometer. Having had many BMW's (5 in the driveway now) what I hear is a sticking lifter. If I were to make a suggestion to you that may help. Get a can of SeaFoam & add to the crankcase. It will not hurt your engine. This is pretty good stuff to clean any deposit(s) I have used it in the past, just for normal internal engine cleaning. I would usually add it 300-400 miles before next oil change, this way cleaning inside lifters and oil passages, then do my oil change. Got a can on the bench right now wait until it's time. Check it out here.
http://seafoamsales.com/auto/
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 03-11-2016, 02:07 PM   #3
mr ilia
My Ride: 2004 BMW 325i 5spd
If you know it is your valve lifters ticking, then Sefoam the engine. Have in your crank case for about 500-1000 mi before your oil change.
Also bad cam position sensor will cause engine to tick, injectors actually would tick with the bad sensor.
May be your injectors are ticking and not valves?
Loud injectors are nothing to worry about.
You will have to isolate the source of noise.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 03-11-2016, 03:07 PM   #4
gslother
Not the lifters
I understand what you mean with the sea foam however I had all the lifters replaced and the noise remained the same. It's defiantly not the cam position sensors I had both replaced. This also isn't the injectors.
Old 03-11-2016, 03:11 PM   #5
Silverdogz
My Ride: 2002 BMW 330Ci
Are any of the belts shifting around?
Silverdogz is offline   Reply With Quote
Old 03-11-2016, 03:50 PM   #6
bimmernut3
@GS......if the walls of the lifter inserts have any "GUM" on the walls or if the hydraulic channels to them are restricted, they will "stick" & make that tapping sound. Spend the $8 bucks & try the SeaFoam. At the least, it will clean things & $8 bucks is not expensive to at least rule that out. Just sayin.....We're here.r at least me, trying to help you, not send you on wild goose caches.
'05 330ci
[IMG][/IMG]
Old 03-11-2016, 03:56 PM   #7
gslother
Understand, I will try that. Still have a few thousand before next oil change. I hope that will work. Noise is driving me crazy!
Old 03-12-2016, 08:15 AM   #8
markusmarkus
My Ride: 2001 330Ci
How do you drive the car? Do you accelerate to redline occasionally? These engines are highly tuned and need to be "pushed" every so often. I have a friend with a 2002 330i. She drives the car like a grandma would. The engine developed lifter ticks. She spent a lot of money trying to get rid of the ticking. I told her take the car on a 20 mile highway speed+ run in 4th gear (it's a 5-speed manual) on a weekly basis. Her ticking noise is gone!
Old 03-12-2016, 01:32 PM   #9
Dave1027
My Ride: '06 IR zhp coupe
Could it be an exhaust manifold leak? Seems like the noise is loudest on the passenger side wheel well.
Old 03-12-2016, 03:16 PM   #10
Phillips0417
My Ride: 03 330i ZHP
Bingo, this is what I was going to suggest as well. Sure seems like the sound is louder / more prominent on the exhaust side of the engine.
Phillips0417 is online now   Reply With Quote
Old 03-13-2016, 02:01 PM   #11
gslother
Would that make sense that on cold starts it does not make the noise untill it gets up to temp?
Old 02-02-2017, 09:20 PM   #12
derek502
My Ride: 2004 330ZHP
Did you ever fix the ticking noise? My ZHP is making the exact same sound.
04 330 ZHP coupe
06 530i-wife's car
02 Dodge Dakota QC-4.7 with some mods
06 Dodge Ram 3500 Cummings
derek502 is offline   Reply With Quote
Old 02-02-2017, 09:23 PM   #13
gslother
Derek never fixed it. Sold the car couldn't take the noise.
Old 03-31-2017, 08:13 PM   #14
tiggaatl
My Ride: 05 330i ZHP
Send a message via AIM to tiggaatl Send a message via Yahoo to tiggaatl
Has anyone found any information for this? My ZHP is doing the same thing
~"I mod, therefore I am"~
tiggaatl is offline   Reply With Quote
e46, tapping, ticking noise, zhp
