Old 03-15-2016, 11:41 AM   #21
mr ilia
My Ride: 2004 BMW 325i 5spd
Your whole drivetrain might be shifting under stress.
Engine mounts, transmission mounts and diff bushings may need to be checked and changed if worn out.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 03-15-2016, 04:20 PM   #22
sprintman
My Ride: Ex 325CI owner
Originally Posted by yamman93 View Post
I changed mine with redline MTL and now my shifts are pretty smooth when the transmission is warmed up. I live in California so the weather never gets below 50 degrees. Now when it's cold outside, my transmission can be a little hard to get into gear so if you live somewhere were it actually gets cold, you might want to consider using the oe fluid.
Sent from my iPad using Tapatalk
Redline D4ATF much better than OEM
sprintman is offline   Reply With Quote
Old 03-16-2016, 03:29 AM   #23
yamman93
My Ride: 2006 330ci
I was thinking about using the redline atf and I'm thinking about trying it. I've heard it gives buttery smooth shifting
yamman93 is offline   Reply With Quote
Old 03-16-2016, 04:04 AM   #24
sprintman
If you drive it during winter how cold does it get?
Old 03-16-2016, 08:13 AM   #25
markusmarkus
My Ride: 2001 330Ci
Sprint, OP is in Canada! D4ATF FTW!
Old 03-16-2016, 10:38 AM   #26
Jaundiced Outlook
My Ride: has a tailgate
OP, hopefully your problem is something simpler (fluid, CDV), but another thing to consider for jerkiness when shifting, especially in lower gears, is a failing dual mass flywheel. When mine started going bad I had to baby it in the lower gears. It made it really hard to shift smoothly.
In RealOEM it appears the 320i has the same transmission, clutch and flywheel setup as 325i. If that's the case, you could ditch a bum DMF and install a SMF conversion kit like I did on my car.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 03-16-2016, 11:59 AM   #27
mr ilia
Speaking of SMF conversion from Valeo.
Anyone know what is actually different between 01-02 325 clutch and 03-05 325 clutch?
Part numbers different for both SMF and DMF setups.
Old 03-16-2016, 02:52 PM   #28
yamman93
My Ride: 2006 330ci
In winter it gets like 46 degrees at the absolute worst. I have never seen snow fall within a 100 mile radius of my home. So I think D4 would be okay right?
Old 03-16-2016, 03:22 PM   #29
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
I don't have experience with changing it on an E46, but I do have a positive experience with the change on another car.
A common upgrade for the original Sentra SE-R was a short shifter, however, it made the shifts rather notchy. The switch to Redline gear oil almost universally improved the shift quality. I certainly noticed it. While most gear oil producers have a package of additives, it seems the Redline gear oil has some additives that help the synchros mesh more smoothly. Motul makes an excellent gear oil for manual gearboxes, but I'd rather roll around in cat poop than get a drop of that stuff on me. That is the most foul smelling stuff. I used it once and vowed NEVER again.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 03-16-2016, 06:41 PM   #30
sprintman
46F is roughly 7C so warm winter?? I thought all Canada was colder than that in winter unless of course you meant -46F?
Old 03-17-2016, 04:24 AM   #31
yamman93
My Ride: 2006 330ci
I live in California. Not Canada. Southern California so always warm.
Old 03-17-2016, 04:47 AM   #32
sprintman
Then Redline MTL is the correct fluid
Old 03-17-2016, 05:05 AM   #33
aba4430
My Ride: 98 Z3 2.8, 00 328Ci
Just FYI - I run Pentosin MTF2 in the 328Ci and 98 Z3, 2.8. No issues thus far.
aba4430 is offline   Reply With Quote
Old 03-17-2016, 08:35 AM   #34
Snowbird
My Ride: 02 325i
Pm me. I live in Southern California, Redlands to be exact. And the amsoil synchromesh was the best thing in my manual trans. It's a thicker fluid than the atf but it doesn't get cold enough here to need the thin atf style fluids
Snowbird is offline   Reply With Quote
Old 04-09-2016, 01:32 AM   #35
xBlackBillGates
My Ride: 320Ci Cabrio
Hopefully your tranny doesn't end up like mine. First was the clucking, then rough shifts, followed by some vibrations, and now a trip to the dealer and 2000 later I find out the deep groove ball bearings went out and took the clutch and flywheel with it. However without the cdv I could have detected clutch wear sooner so I will definitely be performing a fluid flush for my diff, tranny, and master and slave cylinder along with the a cdv delete. All of this from a 2 owner car (I'm the second) first was a 63 year old germany woman.
xBlackBillGates is offline   Reply With Quote
Old 04-09-2016, 09:40 AM   #36
zander271
My Ride: 6spd ZHP/5sp XI
Rofl that's how I feel when I've changed the dif fluid on my cars.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
atf, fluid, manual, redline, transmission
