Old 03-30-2016, 11:25 AM   #1
bimmerboycam
My Ride: 323i
Transmission Error Codes
Hey guys, I've done a lot of research on how to fix this but haven't come across anything specifically for my problem. I took my BMW 323i 1999 to European Motors because it was stalling at low rpms and they diagnosed the problems as a MAF problem so I bought a junkyard oem part and popped that in my E46. While changing the MAF I noticed a tear in the upper intake boot so that was replaced aswell. It began stalling again so I looked into it further. The dealership didn't say anything more other than the MAF and reprogramming it but I got multiple codes when taken to autozone to get it tested. According to the scan codes, my camshaft position sensor, many transmission problems such as gear ratio problems, and misfiring. I replaced the camshaft position sensor to fix the stalling and misfiring problems and it hasn't acted up so far. Now I want to fix the transmission errors. I asked the dealership to take a look at my transmission and they said it was fine...the scan codes say otherwise. Once in a while the car hesitates to change gears but never goes into limp modes. What could be the problem? I can post the error codes they gave me when I get home.
Thanks guys! I'd really appreciate it.
Error codes included:
gear ratio
transmission control unit
bimmerboycam is offline   Reply With Quote
Old 03-30-2016, 01:46 PM   #2
HakenTT
My Ride: 323i with S54
gear ratio code is, low on fluid or clutches are worn out.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 03-30-2016, 03:41 PM   #3
bimmerboycam
My Ride: 323i
P0732 - Gear 2 incorrect ratio
P1751 - Shift valve 1 performance
P0727 - Transmission control module
P0720 - Output speed sensor circuit
P0705 - Transaxle range switch fault
P0763 - Shift solenoid "C" circuit continuity - power short
P0740 - Torque converter clutch circuit open
P0731 - Gear 1 incorrect ratio
P0743 - Torque converter clutch circuit open
P0734 - Gear 4 incorrect ratio
P0733 - Gear 3 incorrect ratio
P1750 - Shift valve performance
P1749 - Unknown
P1748 - Unknown
P1747 - Unknown
P1765 - Unknown
transmission
