E46 Xi Forum
Old 04-10-2016, 04:55 PM   #1
BMWninja
My Ride: 2005 325xi
Suspension - Sachs/Koni Combo?
I'd intended to refresh my 05 325xi's suspension using Sachs shocks and struts but Koni struts seem easier to find, and significantly less expensive. Does anyone see a problem with putting Sachs shocks on the rear and Konis on the front? Common sense tells me that sticking to one brand would probably be ideal, but maybe it doesn't matter so much. Thoughts? Thanks!
BMWninja is offline   Reply With Quote
Old 04-11-2016, 11:38 AM   #2
Kubica
My Ride: 2003 325xi
Stick with one brand. Buy the Koni struts for Xi and e36 m3 rear koni shocks.
Old 04-12-2016, 12:01 PM   #3
dlmrun2002
My Ride: 325xit
So the e36 M3 rear Koni's will fit a 325xit? If so why the e36 M3 besides being little stiffer?
dlm ny country
dlmrun2002 is offline   Reply With Quote
Old 04-13-2016, 05:55 PM   #4
BMWninja
My Ride: 2005 325xi
So, all Koni would be better than all Sachs? My mechanic wants to use all OEM (Sachs, going by the part #s he listed), saying that Koni and Eibach are known to leak/squeak some.
OEM is supposed to be the smoothest and most reliable way to go, yes? (That's what I *think* I understand from the lengthy-but-helpful sticky on the subject, here.) I was leaning away from Sachs due to cost, but the Koni struts are in the same $200- $300 range as the Sachs seem to be.
Old 04-14-2016, 01:25 PM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
No, the Koni Sports are far superior to the Sachs OE dampers. Also realize that your mechanic would NOT be making any Profit on the dampers if you personally buy them & bring them to the mechanic for him to install.
Having the ability to adjust the Koni Sports is a GREAT thing, the front struts can be adjusted in seconds, the rear shocks are unfortunately a PIA to adjust.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
suspension
