Old 04-11-2016, 07:16 PM   #1
JessluvsherBMW
My Ride: 2001 325i Black e46
Help... Car will not move!
My car won't move... It sounds terrible! Several popping noises from the right rear wheel ... Motor is fine, no codes, no leaks, no noises. Trans will not go into R or 5th now...
Car description: 2001 325i manual sedan e46 218,000 on odometer but motor was rebuilt 40,000 ago. 245/45/18 all around.
Any suggestions? I'm a single woman, battling cancer and on limited income. I can't afford a goose chase. Please advise the most cost efficient remedy. New used Tranny? Clutch? Bearing? Axle?
I appreciate any help I may get. Thank you for reading.
JessluvsherBMW is offline   Reply With Quote
Old 04-12-2016, 08:50 AM   #2
SoloII///M
My Ride: Many
We will need more information. What was the car doing before this? You say the right rear wheel is making noises but the transmission won't go into 5th or reverse? Are you sure the noises aren't coming from the transmission? Does the clutch feel normal? Does the gear lever slot into each gear normally? Do first through fourth engage normally? Can you look under the rear of the car to see if there is a problem with either of the rear drive axles?
JV
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 04-12-2016, 08:52 AM   #3
zander271
My Ride: 6spd ZHP/5sp XI
Does the clutch petal have a grinding feeling when depressed?
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 04-12-2016, 09:58 AM   #4
venerated
My Ride: 325xi / Mazda3
Have you left your parking brake on for any long amount of time? (dealing with this now and the car wouldn't move after sitting for a few days, new parking brake parts are in the mail )
Progress Thread / Twitter / Instagram
2003 325xi Jet Black/Brown Leather
2016 Mazda3 s Grand Touring Jet Black Mica/Black Leather
Originally Posted by mpvue View Post
a list of parts to replace on these is easy; just replace everything.
venerated is offline   Reply With Quote
325i 2001, drivetrain, e46, transmission
