Old 06-21-2016, 01:41 PM   #1
Schultz93
My Ride: 323ci convertible 00
E46 323ci wierd engine noise
Hello
I have Got this wierd problem/Sound that i cant figure out where comes from..
It appears when the car is idling and i Press the break, going to 1. Gear and the just release the clutch till the rpm lowers..
Can be done without using clutch when rpm is lowering but its the easiest Way to make it appear.
Any help?
m52tub25 2000
video link:
Schultz93 is offline   Reply With Quote
Old 06-21-2016, 01:52 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
so if you drop your rpms below 700 it makes this sound? does it make the noise all the way down to 0 rpm (if you stall it on purpose)?
did this sound just appear one day? to me it sounds like the normal sound of the engine bogging, but amplified which makes me think it could be a failing or failed engine mount.
Old 06-21-2016, 01:59 PM   #3
Schultz93
it does it everytime i drop it below 700 and its pretty loud - ppl think it sounds wierd (mechanics
when it gets even lower (almost killing it) it stops - and i cant maintain the sound
Old 06-21-2016, 02:04 PM   #4
peytonracer4
:D
My Ride: '00 328i
yeah it's hard to say with a video. i'd recommend having someone bog it like you're doing in the video and have a good look around to see if something is rattling. again, my first guess would be engine mounts though. my car actually made a similar noise come to think of it and it went away after changing the mounts.
Old 06-21-2016, 02:06 PM   #5
Schultz93
allright - i got someone in another forum with same problem - where ppl are mentioning airflow meter, and some "breathers?" (im danish and the google translate version is breathers)
Old 07-24-2016, 04:51 PM   #6
Schultz93
Anyone seen this, still havnt Got it solved
Old 07-24-2016, 08:31 PM   #7
trentcdrums
My Ride: BMW 323i Sedan
Clean your idle control valve..
323ci, engine noise, rpm, sound
