Old 06-25-2016, 05:15 PM   #1
Gtmatthew
My Ride: 325i
Just bought a 325 to turn into a tack car....Now what?
Hello BMW world, I'm a new guy to BMWs but my brother and a few of my friends have had them for years. Anyways I wanted to get into autocross and track days, so on Craigslist I found this 01 325 it had 2 engines and 3 trans and a ton of parts, got it for a steal. The interior is mostly gone, no engine in it currently, have a 330 engine to put it in with the 6speed is the plan and sell the 2.5 and 5 speed that came out of it. So my question what does the community think are essential things I should do to the car to have fun at the track, this will not be a daily driver.
I'm thinking, race seats, 5pt harness, race steering wheel, ss brake lines, 4pt cage. If I can afford it new wheels and tires.
Any other suggestions? Thanks
Gtmatthew is offline   Reply With Quote
Old 06-25-2016, 05:31 PM   #2
gusthehater
Lots of things.
-assuming that the subframe isn't damaged(common on the pre MY 2002)
Better breaks. Better suspension. Wheels/tires are paramount for a track car. Make sure ALL of the routine maintenance items are up to par. Start with that stuff before you start into roll cages, etc. car won't look cool, or be fast if the engine overheats on the first lap.
gusthehater is offline   Reply With Quote
Old 06-25-2016, 07:21 PM   #3
Inigo Montoya
My Ride: 2009 BMW 328i wagon
maybe start here: http://spece46.com
Inigo Montoya is offline   Reply With Quote
Old 06-25-2016, 07:24 PM   #4
Gtmatthew
My Ride: 325i
Thanks, that's what I have been reading and finding out, the m54 motor I'm putting in it is out of the car, thinking I should do any of the seals that are hard to get to, like the rear main, oil pain, valve cover, any others anyone can think of?
Old 06-25-2016, 07:33 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
ATI damper. New rubber brake lines not SS. New fluids everywhere. Muffler delete to reduce weight. Possible a fully stainless radiator and a stainless expansion tank.
Old 06-25-2016, 08:03 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP,
You might want to search the threads I've created.....
Keep the 2.5L & sell the 3.0L.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 06-25-2016, 08:56 PM   #7
Gtmatthew
My Ride: 325i
Thanks rob, I think that's what I'll do, you know anyone in the market for a 3L and a 6speed? Haha
Old 06-25-2016, 08:56 PM   #8
Gtmatthew
My Ride: 325i
Why not the ss brake lines?
Old 06-25-2016, 09:17 PM   #9
peytonracer4
:D
My Ride: '00 328i
Because brake lines are a wear item when racing and should be replaced every season. SS don't really offer much benefit compared to a brand new rubber line. And rubber lines aren't going to break the bank every year.
Old 06-25-2016, 09:48 PM   #10
orb
orb's Avatar
My Ride: 325Ci
A 5 speed 325 with a 3.46 diff is a respectably quick car. I'd get the diff, headers, and poly/M3 bushings where applicable.
orb is offline   Reply With Quote
Old 06-25-2016, 10:08 PM   #11
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Why?
///Mmmmmm...
Old 06-25-2016, 11:08 PM   #12
Rob43
Rob43's Avatar
Originally Posted by BaliDawg View Post
Why?
Certainly a good question.
3.0L motors have a Much Higher tracked failure rate.
2.5L motors don't.
Rob43
Old 06-26-2016, 12:06 AM   #13
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
I'm thinking lots of maintenance first. Cooling system. Suspension bushings. Control arms. Track pads.
All the stuff you're thinking is gee-wiz, but if you really want to enjoy it as a track car, start with the basics.
The car I first drove in SCCA school and my first races (in IT) had a stock seat (yep!), stock steering wheel, stock struts with Pro-Kits, and a bolt-in cage. Not exactly glamorous. But it was dead reliable and we added the gee-wiz stuff as we went along.
The LeMons car we raced (same platform as our SCCA IT car) was every bit as good, and perhaps even better.
Take care of ALL the basics first. You can show up on a track day with all the fun stuff and if your car doesn't run you look like an idiot.
Of all the things you mentioned, the race seats are about the only thing I would call a priority, and even that's not a given. SS lines would come after track specific pads (changed out upon arrival at the track and just before leaving).
I've race on and off more than half my life. What I can tell you works best is seat time. That means reliability. If you're building a race car, you need to read the rule book. Then read it again with a highlighter and make notes in the margins.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is online now   Reply With Quote
Old 06-26-2016, 06:22 PM   #14
Gtmatthew
My Ride: 325i
Thank you all for all the suggestions! I'll get all the Maintenon stuff done then worry about the cool stuff
Old 07-07-2016, 07:20 AM   #15
pvaultguy
My Ride: 2004 330i
I think you learn better if you make incremental improvements to the car instead of all at once. Focus on working your way up the HPDE classes first, mods second. Safety and reliability step 0.
pvaultguy is offline   Reply With Quote
325, track car
