Old 06-27-2016, 12:31 PM   #1
shields42
My Ride: '00 323i Sport Wagon
Whistles/whines from engine in strange conditions
My 2000 323i Sport Wagon is making a couple very strange whistle sounds. Here are the conditions for the first one:
1) It only happens in Drive - not Park or Neutral
2) It is not affected by the AC being on or off
3) It is only audible at low RPM (1200-2500)
4) It does not occur at idle
5) It decreases in pitch as the throttle increases
6) It goes away as soon as I lay into the throttle.
7) It seems to be inconsistent with RPM and more consistent with throttle position
The other noise happens under these conditions:
1) It only occurs at 5000 - redline
2) It only occurs in Drive
3) It does not happen if I gently bring the car to redline
4) It only present when I put my foot to the floor
And suggestions on where to start?
shields42 is offline   Reply With Quote
Old 06-28-2016, 07:56 AM   #2
markusmarkus
My Ride: 2001 330Ci
Sounds like the tranny may need attention. Automatic tranny, correct? I'd have the tranny fluid level checked first. When was the last time the tranny fluid and filter were changed? BMW's "lifetime fluids" was a marketing ploy and not a maintenance philosophy.
markusmarkus is online now   Reply With Quote
Old 06-28-2016, 08:13 AM   #3
BKMrSteel
My Ride: 99 328i
Do a simple belt test before more expensive things. Take the belts off, check all the bearings and tensioner. Easy check, hopefully nothing more. Good luck!
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
noise, throttle, whistle
