Old 06-29-2016, 08:57 PM   #1
GuillermoZHP
My Ride: 2004 Bmw 330i ZHP
2004 330i ZHP electrical problems
Hello all,
So I recently bought a 2004 330i zhp with 117k miles. Mechanically, the car drives pristine and looks great cosmetically. The only downfall is that the navigation/radio does not work, the gauge cluster lights do not power on, and no ac (does blow air though). On startup the BMW logo does come on but shuts down seconds later. The dash lights for the speedo, tach, turn signals etc. don't turn on but the exterior lights all work fine and it does display miles etc.
Before buying I thought it would be a simple electrical problem, but it has turned into a headache that I can't figure out. I have looked all over forums, googled but no luck. I also messed with the Kbus but no luck either.
Any suggestions would help greatly because I really don't want to resort to dealership help yet as I feel this is something I could fix myself.
Thanks!
GuillermoZHP is offline   Reply With Quote
Old 06-29-2016, 08:58 PM   #2
GuillermoZHP
Also, the previous owner did have a dice hooked up but took it out a couple months before I bought it.
Old 06-30-2016, 07:41 AM   #3
markusmarkus
My Ride: 2001 330Ci
The DICE module isn't the problem! It does sound like the k-bus is fubar'd. Google "BMW E46 troubleshooting k-bus." There are several tutorials on troubleshooting fixing k-bus problems.
Old 07-03-2016, 08:19 PM   #4
GuillermoZHP
Thanks for the input! Will definitely keep reserching.
Old 07-04-2016, 01:59 AM   #5
mikeetastic
My Ride: lots of 3
Do you have a spare cluster you can borrow? From another car e46 just to rule out its not the cluster?
mikeetastic is online now   Reply With Quote
Old 07-04-2016, 02:40 AM   #6
zander271
My Ride: 6spd ZHP/5sp XI
Check your fuses
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 07-04-2016, 10:25 AM   #7
GuillermoZHP
I don't atm. I was about to pull it out and inspect it.
Old 07-04-2016, 10:26 AM   #8
GuillermoZHP
Originally Posted by zander271 View Post
Check your fuses
I checked them all one by one, no luck.
Old 07-04-2016, 12:43 PM   #9
mikeetastic
My Ride: lots of 3
Check this thread out http://forum.e46fanatics.com/showthr...729&highlight=
Looks like your issue above.. I would borrow a cluster from any e46 just to rule the cluster out. It will throw a tamper dot and asc dsc light but you can test functonality before opening your zhp one. You can also pull your zhp cluster and test on another car and do the #2 hidden cluster test.
Old 07-04-2016, 12:53 PM   #10
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Sounds like a bad cluster (no lights/gauges except ABS, seat belt and gauges backlight). That's the standard failure I see coming in.
The nav/radio however is probably a separate problem. That one I don't repair.
scottjoh is offline   Reply With Quote
Old 07-04-2016, 08:54 PM   #11
GuillermoZHP
Something else I have failed to mention is that when we were having heavy rains in San Diego this year, water was leaking down the passenger A-piller to the point where my carpet was soaked. The fuse box showed signs of rust. Some more symptoms would be that when the car has been off for awhile the remote locking system works flawlessly. When I turn on the ignition, the locking system no longer responds to the remote. Furthermore, the Kbus will show 12v when the ignition is off, but will drop to 11.7v when the ignition is switched on.
Old 07-04-2016, 09:42 PM   #12
scottjoh
Modded ///Member
K-bus voltages are perfect. Check the back of the fuse box for corrosion, give the wires a tug if it's corroded because the copper can get completely eaten away inside the insulation. I still think the cluster is bad. If you send it in I can test is and repair if necessary.
330i, electrical problems, zhp
