Moody starting problem - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-31-2016, 05:04 PM   #21
Tini_Lynn
My Ride: '03 325i
Its an Actron don't know the model rn
Tini_Lynn is offline   Reply With Quote
Old 07-31-2016, 05:06 PM   #22
Tini_Lynn
My Ride: '03 325i
Yeah after I deleted the code the stft was showing something and ltft wan at 0
Old 07-31-2016, 05:23 PM   #23
jfoj
My Ride: 330CiC, M5, X5, E93
Well you only have the Acton tool at the moment, however, I would toss it directly in the trash if you gave it to me.
HIGHLY suggest you get OBDFusion and learn how to use all of its features, less than $20 on Android and less than $30 on iProducts. This includes the interface.
Old 07-31-2016, 05:54 PM   #24
Tini_Lynn
My Ride: '03 325i
What the actual f*ck. Ok I had already got a new MAF when I seen that it was probably A wiring problem. So I put in the new one and now it starts everytime but idles like sh*t. And I'm getting enhanced codes for P0300, P1345 and P1347.
Old 07-31-2016, 05:56 PM   #25
Tini_Lynn
My Ride: '03 325i
Oh and if I have no MAF in at all my car starts and runs f*cking perfect!
Old 07-31-2016, 05:59 PM   #26
jfoj
You are a new user here.
You probably do not understand how much data is needed to actually help you.
OBDFusion can Log and provide data for each PID and then we can see what is going on.
If you have the old MAF, put it back on the car.
Learn how to Smoke Test.
Learn how to provide Freeze Frame data.
Suggest you look at this post - http://forum.e46fanatics.com/showpos...0&postcount=19
Learn how to provide warm idle Fuel Trim data.
Old 07-31-2016, 06:00 PM   #27
jfoj
BTW, when you unplug the MAF, the fuel management system goes into a Speed/Density mode with an overly Rich fuel Map that usually masks vacuum leaks and Lean problems.
Old 07-31-2016, 06:22 PM   #28
Tini_Lynn
My Ride: '03 325i
Alright I ordered the adaptor for the obd fusion I should get it here in a week in the mean time I'll try to learn to do a smoke test.
Old 08-02-2016, 02:15 PM   #29
lingon300k
My Ride: 2005 325xi Automatic
How do you smoke test without a machine?
lingon300k is offline   Reply With Quote
Old 08-02-2016, 02:25 PM   #30
jfoj
YouTube is your friend!
Cheap fluid transfer pump from your local auto parts store or Amazon.
http://www.amazon.com/ABN-Multi-Use-...fer+pump&psc=1
A few rubber gloves, rubber bands and some cheap mini cigars from our local gas station or convenience store.
Also get a good, bright LED flashlight to locate the escaping smoke. Look deep in the engine compartment and under the engine if needed. Do not forget the dipstick guide tube and the lower CCV oil return line. These areas may be hard to see from above in the engine compartment.
After looking for intake air leaks, remove the oil fill cap and allow the crankcase to fully fill up with smoke, then replace the oil fill cap. Check for cracks in the valve covers and leaks around the grommets, half moons and around the perimeter of the valve cover.
Common areas of leaks:
Upper and lower intake boots
Upper intake boot around F connector
DISA main O-ring and shaft area
Vacuum hoses under the rear of the intake
Fuel pressure vent hose that connects to the F connector on the upper intake boot and under the drivers floor board where it connects to the fuel pressure regulator
CCV and hoses, especially the lower oil return line
Dipstick and dipstick guide tube
Oil fill cap
Valve cover gaskets and cracked valve covers
SAP vacuum line to Kombi valve on front of engine, this will not leak smoke because of the control valve under the rear of the intake
Power brake booster sucking jet pump and hoses.
Note that the brake booster usually cannot be smoke tested because of the input vacuum check valve at the booster connection.
After you find a leak, make sure you re-test as there can be many smaller leaks on these cars.
Old 08-02-2016, 02:34 PM   #31
lingon300k
Oil fill cap
Yes. I've seen that before but forgot about it entirely.
Have you tried this? Does it work well?
I don't have any reason to smoke test the BMW right now, but my Volvo is desperately in need of it.
Old 08-02-2016, 02:53 PM   #32
jfoj
Cheap and easy to do.
Cheap fluid transfer pump that is available at almost any auto parts store.
https://www.amazon.com/Hopkins-10803...+transfer+pump
A few rubber gloves and rubber bands and some cheap $3 cigars from the local gas station or convenience store.
Does not matter the make or model of car or truck, same procedure. Check intake and crankcase.
Old 08-05-2016, 01:40 PM   #33
Tini_Lynn
My Ride: '03 325i
Ok I did a smoke test and didn't see smoke leaking out anywhere except a small amount where I didn't have my rubber bands tight enough. I'm gonna try again tonight when it's darker and I can use the flashlight hopefully and leaks would be more visible. And my veekpeek (I think that's what it was) should be showing up some time today so I should be able to get some better readings.
Old 08-05-2016, 05:32 PM   #34
Tini_Lynn
My Ride: '03 325i
Ok my MAF is still showing at 0.00 it's in lbs/min not grams/second. Idk how to change that. My FTRM values are kinda confusing. This is warm idle. I have one showing bank 1 another says bank 2
Bank 1: ST = -6.25%. LT = 0%
Bank 2: ST = -9.38%. LT = 0%
It also shows Short term fuel trim values for each sensor. Idk what this means so I will just post them all
Bank 1: Sensor 1 = -7.03% | Sensor 2 = 99.22%
Bank 2: Sensor 1 = -10.16% | Sensor 2 = 99.22%
Old 08-05-2016, 05:37 PM   #35
Tini_Lynn
My Ride: '03 325i
On my freeze frame all the fuel trim values are at 0%
Old 08-05-2016, 05:40 PM   #36
Tini_Lynn
My Ride: '03 325i
And this data is using the OBD fusion that was suggested
Old 08-05-2016, 05:48 PM   #37
Tini_Lynn
My Ride: '03 325i
Note: idk if this OBD reader is supposed to do this but on my dashboard on the OBD the batter voltage meter. While the car is running my voltage keeps dropping to 0 and then popping back up to 13.5v
Old 08-05-2016, 06:30 PM   #38
Tini_Lynn
My Ride: '03 325i
Since you said that I shouldn't be getting a 0 MAF reading I was googling causes of that and found a forum (not BMW specific) with a similar problem the issue ended up being the MAF connection to the computer... Now just to figure out how to find which connection that would be lol
Old 08-05-2016, 07:06 PM   #39
jfoj
You need to learn how to add gauges to the dashboard on OBDFusion. Use Google, YouTube, spend 20 minutes playing with the App.
Change the MAF reading from lbs/min to g/s under Settings, Units, Airflow as I recall.
Read this and set up Logging properly. PDF - http://forum.e46fanatics.com/showthread.php?t=1097893
Watch the MAF reading on the Dashboard while the engine is running and make sure the MAF is plugged in, then wiggle and pull on the MAF wiring near the MAF and near the wiring box at the throttle body and see if the MAF value all the sudden starts to appear.
You either have a bad MAF, which they rarely hard fail and have no output, or a MAF connection/wiring problem.
DO NOT buy a MAF from the local auto parts store. You will regret it. A quality MAF that will actually work will set you back close to $200. Borrow on for a test if you can, even if it is not for the car specifically. If it has a similar connection and is a Siemens/VDO, it could be used to test.
There are 3 and 5 wire MAF. So this is the first hurdle.
Old 08-06-2016, 10:45 AM   #40
Tini_Lynn
My Ride: '03 325i
Oh snap. This thing it more awesome than I thought. I had been playing with that app for a couple hours but I still didn't know I could add stuff. So I added a dash board with Fuel trim values and labeled them. And I got the MAF unit switched. Also set up the logging as requested. You, idk who you are but you are some kind of super hero cause I've already learned so much. Do you have anyother suggested gauges I should add? I had also already returned the MAF I had bought. Luckily they took it back. I agree it's more likely a problem somewhere with the wiring. So I'm gonna try and dig around a little more today. I'm usually in a hurry cause where I live doesn't like you working on your cars so I get like and hour time limit before I have to put everything up. Honestly most of yesterday's hour was spent getting my car started and trying to figure out the app. I also spent a good 10min wondering why I couldn't post any responses on here before I realized I was still connected to the veekpeek ***55357;***56837; Thanks so much for all this help btw!
325i 2003, maf, standard transmission
