Old 08-11-2016, 11:47 AM   #1
shields42
My Ride: '00 323i Sport Wagon
Weird errors all over the place
My 2000 323i wagon blew a coil 2 days ago and I replaced it same-day with a BREMI coil. Worked like a charm for all of 16 hours.
Yesterday afternoon, out of nowhere, my car begins to shudder, lose almost all power, and throws SES, EML, and DSC. I pulled over, turned it off, waited 30 seconds, and turned it back on. SES was the only light that remained. At that point, I put the hazards on, and made a very slow bee line to Advance Auto to get the codes read. P0101 (MAF error) and P1510 (ICV error). I got some MAF cleaner and was on my way. I removed the MAF, sprayed the crap out of it as per the directions, and waited about 30 minutes for it to dry. I reinstalled it and went for a test drive. All was well. I got the code cleared and and headed home. Later that night, I went over to a friend's house (5 miles) and the same trifecta of lights came on and the car went into limp mode. I read that low ATF can cause this, so I topped off the ATF reservoir and crossed my fingers. I waited about 20 minutes and went for a test drive. Sluggish, underpowered, and lots of radiator fan noise. I decided to call it a night and try to continue diagnosing tomorrow.
This morning, I turned on the car, and all the lights were off. No issues getting to work at all. It drove like it usually does! It was very unsettling...
So what do I do here? Any thoughts on what the root cause of my mini disasters?
2000 323i Sport Wagon
shields42 is offline   Reply With Quote
Old 08-11-2016, 12:47 PM   #2
2003silver330i
My Ride: 03 BMW 330i
Since the problem didn't exist before the coil change I would start checking for a broken, disconnected, or pinched vacuum hose around the valve cover. Maybe even a loose engine harness connector.
The 2 happiest days of a BMW owner's life is the day they buy it and the day they sell it.
BMW (Broke My Wallet)
2003silver330i is offline   Reply With Quote
Old 08-11-2016, 01:38 PM   #3
shields42
The valve cover being the black plastic piece that says ====BMW== on top?
Old 08-11-2016, 02:41 PM   #4
Onizukachan
My Ride: `04 M56 Touring
How are you:
A: checking the atf since there is no dipstick
B: topping off the reservoir since there is no reservoir?
I think you just checked your power steering fluid.
If I were to give my Touring a first name, I'd probably name it "Alan".
Mostly because I like puns.
DIY: E46 Touring TV Tuner Install/Mounting
DIY: Wiring City Lights, Rear Fogs, and Rear Camera in a Touring
Onizukachan is offline   Reply With Quote
Old 08-11-2016, 02:47 PM   #5
shields42
Ah son of a bitch. It was definitely steering fluid. It said ATF only, so I assumed it was for ATF! And there are little rings on the bottom of the cap that I assume indicated safe levels. So I raised it to the middle ring. Guess I'm all set on power steering fluid. So we think it might be an issue with the black engine cover pinching something?
Old 08-11-2016, 03:41 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
See my signature below for the Hidden OBC Menu, watch the charging Voltage and make sure this is not a problem. 13.5-14.5 Volts when the engine is running is typical.
Also get the battery checked at the parts store as well.
Old 08-11-2016, 09:50 PM   #7
2003silver330i
Try cleaning your ICV as well if you don't find any pinch/broken hoses and or loose connectors.
eml, intake, maf, p1510
