Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 08-15-2016, 01:41 PM   #1
FTL_Bimmer
My Ride: 2001 325xiT 5-Speed
Urgent Hatch Glass Replacement - any ideas?
Hey there,
Unfortunately the worst window that could have possibly broken on my touring, broke on the freeway the other day. I don't know how it happened but my rear hatch glass just shattered on I90. So, I need to replace it and FAST, does anybody have a website or possibly a spare I can purchase from them, I'll even buy the whole hatch if I need to.
Thanks!!
325xiT: Dinan SS Exhaust, Dinan High-Flow Air Intake, Dinan short shifter, Koni Yellow Struts, Rob43 Rear Adjustable, Eibach Springs
FTL_Bimmer is offline   Reply With Quote
Old 08-15-2016, 02:08 PM   #2
VpointVick
My Ride: '03 325iT Mysticblau
Good luck.
If you end up with a whole hatch I'd be interested in buying one of your diversity antenna amplifiers from under the spoiler. I suspect that mine isn't working properly causing short range for the key fob unlocking, and buying a brand new one is an expensive test.
VpointVick is offline   Reply With Quote
Old 08-15-2016, 02:21 PM   #3
FTL_Bimmer
For sure, I think I have found a few hatches but we'll see. I'm about to call a junkyard in Oregon to see if they have one as well, if I find a hatch, if anyone needs parts from it let me know in a PM. Thanks!
Old 08-15-2016, 05:09 PM   #4
FTL_Bimmer
I found a hatch and it happened to be the ONLY hatch in WA & OR with glass still in it, so it should be here this Friday or Saturday. It's Forest Green so if you need touring hatch parts let me know.
Old 08-15-2016, 06:34 PM   #5
zander271
My Ride: 6spd ZHP/5sp XI
So I guess I was incorrect about getting just the glass replaced Which is weird because it can be done on other cars.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 08-15-2016, 06:43 PM   #6
FTL_Bimmer
Yeah if you have a touring, good luck finding used/aftermarket glass. All of the glass shops I called said that they couldn't find an aftermarket maker of the hatch glass and the ones who said they would even do the work said they were going to order an OEM piece of glass. In terms of doing the replacement, that can be done by anybody because the glass just bolts on. I think I'll write a DIY for glass lid removal and replacement in case someone has to do it or wants pictures of things being taken apart in case they have to get in there for something. I ended up forking out $500 for a whole hatch from a forest green 325iT.
Old 08-31-2016, 07:07 PM   #7
protomor
My Ride: Jetta... for now
I went through this last year. A tree fell through mine. I was quoted $1200 installed but it even turns out they don't have any new ones anywhere in the US. I had to LKQ and it came from friggen canada! $300 installed at least.
protomor is offline   Reply With Quote
Old 08-31-2016, 07:25 PM   #8
FTL_Bimmer
Hopefully after selling the remainder parts I can approach the $300 range, haha. sof ar I've only sold the FZV antenna
crack, glass, hatch, touring, window
