Old 08-29-2016, 07:12 PM   #1
Hamretro
My Ride: 2005 BMW 320ci E46
DISA is getting on my nerves...
Hi guys,
Just asking for some guidance in regards to what might be causing this noise.
Yesterday I came across an unusual noise from the engine bay which I later found out to be my DISA. It was making a very loud whine but it stops when I pull out the DISA electrical connector.
I've replaced the DISA about 6 weeks ago with no issue until yesterday. I removed the new DISA to double check the o-rings but couldn't fault anything wrong with it. It also holds vacuum and there is no rattle just to be clear.
I've done some recent preventative maintenance which I'll list below.
-Replaced valve cover gasket.
-Replaced VANOS o-rings.
-Replaced CCV filter and plastic vacuum pipes. (Intake manifold was removed so I fit new manifold gaskets and refreshed vacuum hoses.)
-New Tensioners, pulleys and drive belts.
Any help would be greatly appreciated.
Hamretro is offline   Reply With Quote
Old 08-29-2016, 07:16 PM   #2
All2kool
My Ride: 2002 325Ci
OK, I'll ask - did you replace the DISA with BMW OEM of aftermarket EBay? Seems you know what is wrong - the noise does not occur with the DISA not plugged in. I would hope that a warranty is in effect.
All2kool is offline   Reply With Quote
Old 08-29-2016, 07:20 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Is the whine with the engine running or stopped and the ignition on?
Old 08-29-2016, 07:32 PM   #4
Hamretro
OEM replacement with the rtv o-ring, only with engine running.
Old 09-05-2016, 05:19 PM   #5
Hamretro
Still not sure why it only causes the noise with it plugged in? If it was a vacuum leak I would have thought it would make the noise all the time...
Old 09-05-2016, 06:00 PM   #6
All2kool
My Ride: 2002 325Ci
Well that is an odd one. I would have thought it was defective but I gather I am incorrect if it's NEW and OEM.
What was the reason it was replaced? I do hope it wasn't because of the very noise that remained after replacement.
Old 09-05-2016, 06:54 PM   #7
Hamretro
At the time I was trying to figure out another issue where on cold start up the engine would almost stall, The DISA was replaced along with all the vacuum hoses, rocker cover gasket, ccv system etc. But the original DISA wasn't making any noise but after I replaced it the cold start issue was fixed.
Old 09-05-2016, 08:26 PM   #8
Hamretro
If I unplug the DISA electrical connection while the engine is running at idle, the flap will be open right? So there will be no vacuum applied to the flap actuator diaphram because the solenoid will close the path of the vacuum from the reservoir.
When the solenoid is plugged in and engine running below 4000rpm it should allow the vacuum from the reservoir to reach the flap diaphram which will close the flap.
I'm thinking that there must be an internal leak from the diaphram. Orrr the solenoid which has a vent that allows atmospheric pressure back onto the diaphram which should only happen when the engine is above 4000rpm.
Thoughts?
Old 09-06-2016, 09:49 PM   #9
Hamretro
Well, just gunna give in to it. I have warranty for the DISA so I'll replace it again and hope for the best...
Old 09-07-2016, 12:31 AM   #10
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
What noise? Record a video with sound and post a link to it. Without that, we have no clue what it could be. Help us help you.
///Mmmmmm...
Old 09-07-2016, 03:18 AM   #11
Hamretro
I'll post it tomorrow when I get the chance. The best way I can describe it for now is a high pitch whine.
Old 09-07-2016, 10:00 PM   #12
Hamretro
Link to video.
disa, issue, noise
