Old 08-31-2016, 08:45 PM   #1
Gyuri1
My Ride: 2003 320i
Car won't start shortly after using Fuel Injector Cleaner
Hi guys.
I hope you are all doing well. I need your help once again.
My car ran totally fine today until later when I tried starting it again. It fired up multiple times but for a few short seconds only until it stalled. I tried giving it some gas but I was unable to keep the car running. It's as if the pedal didn't even respond.
I am suspecting the STP Fuel Injector Cleaner I put in a full gas tank a couple days ago has something to do with it.
Now it doesn't even start at all anymore. There is power, the flywheel spins but the car just won't fire up.
I think there is simply no fuel going to the engine or not enough at all.
Any help is greatly appreciated, I want to be able to fix this asap.
Thanks to all of you in advance!
Gyuri1 is offline   Reply With Quote
Old 08-31-2016, 08:55 PM   #2
lingon300k
My Ride: 2005 325xi Automatic
Originally Posted by Gyuri1 View Post
Hi guys.
Did you put a single bottle of STP fuel system cleaner in the tank then fill it up? If so, there's no way it has anything at all to do with what you're experiencing. STP fuel system cleaner is worthless, but it won't damage your system or cause your car to not start.
Any codes? Based on the text I bolded, it sounds like your fuel pump just died.
lingon300k is offline   Reply With Quote
Old 08-31-2016, 10:37 PM   #3
Gyuri1
My Ride: 2003 320i
I added the cleaner after filling up the tank as directed on the bottle. The reason I think it has something to do is just because everything was running fine until I put the cleaner in the gas tank. Kind of odd that my fuel pump dies after 2 days of having mixed a cleaner into my fuel...
However the fuel pump definitely is something to consider.
Why would you say the cleaner won't work anyway? I've seen videos where older cars with lost horse power could actually regain some of the power by cleaner their fuel injectors.
Old 08-31-2016, 10:40 PM   #4
Dave1027
My Ride: '06 IR zhp coupe
Maybe the stp was the straw that broke the fuel pump's back?
Old 08-31-2016, 10:41 PM   #5
Dave1027
Old 08-31-2016, 11:02 PM   #6
WDE46
My Ride: '13 128i, '04 330Ci
Or it's just coincidence without any causation. The fuel pumps just die sometimes. Now, I don't know if that's it, but it's a likely culprit. The injector cleaner didn't do anything.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 08-31-2016, 11:10 PM   #7
lingon300k
Usually, when you've just done something to the car and then something goes wrong, the thing that you did was the cause. But it's not possible in this case.
I didn't say that cleaners won't work, but that STP won't work. Use something with PEA, like Redline SL-1 or Gumout All In One. STP is even worse than I thought if they're directing you to put it in a full tank of gas. Generally, you put the fuel system cleaner in when the tank is empty, then you fill it up to mix the product in with the gasoline.
It's sheer coincidence that the problem started after using the STP. Did you drive the car for two days after putting it in, then the problem started? If so, it's even more impossible.
You didn't say whether or not you have a check engine light, or what the codes are. Usually, you get codes when the car won't start. It's possible, but rare, to have a no-start condition without a check engine light on an OBDII car. Especially a fuel related no-start.
How many miles on the car? Original fuel pump? Even if the fuel pump was dying, there shouldn't be anything in STP that could hurt it.
I don't know what video you saw, but you're getting into bonafide snake oil territory when you start talking about regaining horsepower from an additive. You might gain a bit by having the injectors professionally cleaned, and you might gain a tiny bit of power and fuel mileage from a good cleaner that cleans up the valves and combustion chamber. But this is all a big might. You won't be gaining 10+ HP.
Take a look here, by copy+pasting into google, if you're interested in fuel system cleaners:
search:bobistheoilguy.com+polyetheramine
And read this thread for fuel pump info:
http://forum.e46fanatics.com/showthr...=929501&page=4
Old 09-01-2016, 01:33 AM   #8
Gyuri1
My Ride: 2003 320i
I don't have any code or light that came on. The car has 67 500 original miles which isn't very much but then again probably still has the original fuel pump considering I bought the car around 53 000 miles on the clock.
Now that you guys mention it I think the additive might just be a coincidence and it might actually be the fuel pump.
I will look into it further. The only reason I used additive is not to actually restore horse power but because on very rare occasions the car slightly hesitated on cold starts. I changed the spark plugs a couple months ago, my disa valve, I checked for vacuum leaks but none is present. The car is in overall great shape. So I thought after such mileage some fuel injector cleaner won't do any harm.
Old 09-01-2016, 07:41 PM   #9
jmo69
My Ride: 03 325xi 98 328is
At least pull the back seat to make it easier to hear if the pump primes when you turn the key. If you do replace the pump, do the filter too.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 09-01-2016, 07:46 PM   #10
Landlorder
My Ride: 330CI Sport
Sounds like your fuel pump has gone.
Landlorder is offline   Reply With Quote
Old 09-01-2016, 11:38 PM   #11
Megalocnus
My Ride: 05 330i ZHP/MT
Most likely a coincidence.
Megalocnus is offline   Reply With Quote
Old 09-23-2016, 04:10 PM   #12
Gyuri1
My Ride: 2003 320i
Hi guys.
Just wanted to let you all know that it was indeed the fuel pump. It probably really had nothing to do with the additive. I also replaced the fuel filter as part of a maintenance procedure. Now it runs just as it used to.
All thanks to you!
Why so? I read on a website that it is among the best ones. I mean why would they sell it for that purpose if it doesn't work at all?
Old 09-23-2016, 04:17 PM   #13
WDE46
Hi guys.
All thanks to you!
I'm not commenting on the product you use. I want to make the point that just because something is sold for a purpose doesn't mean it actually works. You probably already know this, but plenty of companies sell **** products that don't work for their intended or claimed purpose.
fuel injector, rough idle, won't start
