Steering Column Wobbly - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 09-06-2016, 03:47 PM   #1
E46CompactTI
My Ride: 316TI
Hi all! I have searched high and low and not found what I am looking for, several threads with no response ect...
Whilst very hard to explain I will have a go, in my car there is play in the steering wheel, not the usual left right when turning the wheel, but if you hold the wheel you can move it up and down about 2mm...
This causes a rattle and vibration type shake when driving and ruins the experience, is there anything I can do to improve this?
A mechanic said it's a result of the PO using the wheel as purchase to lift themselves out the car which has worn the clamp...
Thanks All!!
E46CompactTI is offline   Reply With Quote
Old 09-06-2016, 04:23 PM   #2
All2kool
My Ride: 2002 325Ci
Originally Posted by E46CompactTI View Post
A mechanic said it's a result of the PO using the wheel as purchase to lift themselves out the car...
I don't doubt this one bit - my son's Toyota Tacoma drivers door rubs on the bottom of the door frame when you close it. This is the result of the truck having been lifted and now the door is being used to pull yourself in. There are things on cars and trucks that aren't meant to be used in the fashion in which some use them.
All2kool is offline   Reply With Quote
Old 09-06-2016, 04:25 PM   #3
E46CompactTI
My Ride: 316TI
Yes I know just what you mean, almost as painful as watching people slam cars over speed bumps... Its bearable but so annoying I have to death grip the wheel to prevent the vibration!
Not a compact, a concentrate...
Old 09-07-2016, 07:15 AM   #4
E46CompactTI
My Ride: 316TI
As additional information, I have had the front end checked out and all is secure, bushes and control arms full of life and sway bar end links have about 300 miles on them... So it's defiantly the upper part of the column. I have heard reference to a plastic bushing/baring on the column, is this at all exchangeable?
Old 09-10-2016, 09:44 AM   #5
E46CompactTI
My Ride: 316TI
Anyone?
Old 09-10-2016, 11:09 AM   #6
tommy d
My Ride: 2005 330i
This is probably your issue, scroll down to some vids...
http://forum.e46fanatics.com/showthr...column+coupler
tommy d is offline   Reply With Quote
Old 09-10-2016, 06:19 PM   #7
E46CompactTI
My Ride: 316TI
That is the left right play with couplers mine has no "steering play" eg left or right but the entire adjustable column housing has "up and down play" or wobbles sorry about my dodgy explanations
Old 09-12-2016, 07:01 PM   #8
E46CompactTI
My Ride: 316TI
Also it's seems intermittent... Which is even more strange
Old 09-12-2016, 08:54 PM   #9
glhx
My Ride: 2002 330ci
There is a bearing behind the steering wheel. You take the wheel off and the......clock spring....then it's right there.
These wheels are very easy to take off. Just disconnect battery due to air bag deployment. Don't know if that will fix it but it's there none the less.
glhx is offline   Reply With Quote
Old 09-13-2016, 04:37 AM   #10
E46CompactTI
My Ride: 316TI
Sounds awesome mate! I guess the real hard part is where to source said bearing?
Old 09-15-2016, 04:55 AM   #11
E46CompactTI
My Ride: 316TI
Anyone know where I can gain this bearing and any experience of changing it?
Old 09-15-2016, 09:07 AM   #12
glhx
My Ride: 2002 330ci
Forward motion has hearings but there is usually a supply house with them in your area. I'd get a good one.
If that's even the cause.
The main part is getting the courage to take that wheel off. Whatever you do be careful if regreasing it. Very little goes a long way and you don't want it anywhere else. I have pictures of this somewhere.
Old 09-15-2016, 07:17 PM   #13
E46CompactTI
My Ride: 316TI
Ahhh I was thinking hitting up a bearing shop and going custom! I am going to investigate all steering linkages and get that column cover off and have a good genders to, I may even get the courage up to go to the stealers and ask them... Thanks guys, piccys would be awesome of this mystery bearing if someone has one
Old 09-17-2016, 06:22 PM   #14
E46CompactTI
My Ride: 316TI
As an update to this strange issue it seems to be very temperamental, today I went for a good spin of 100 miles or so and not one shake rattle or anything...
Old 09-26-2016, 10:31 AM   #15
E46CompactTI
My Ride: 316TI
Bump
Old 09-30-2016, 06:00 AM   #16
E46CompactTI
My Ride: 316TI
If it helps there is also a squeak when wiggling the wheel
Old 10-06-2016, 10:33 AM   #17
E46CompactTI
My Ride: 316TI
Can you buy the Upper Steering Plastic Bearing separate from the stealers?
Old 10-28-2016, 05:16 AM   #18
E46CompactTI
My Ride: 316TI
Bump
Old 10-29-2016, 08:30 PM   #19
E46CompactTI
My Ride: 316TI
If you hit the wheel from the bottom you get a loud knock type thump noise where it "loose"
Old 11-07-2016, 04:47 AM   #20
E46CompactTI
My Ride: 316TI
No body?
play, rattle, shake, wheel, wobble
