Lower control arm bushing - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-13-2016, 04:47 PM   #1
BobTheBimmer
My Ride: BMW 325XI 02
Ive searched a few threads looking for answers and Im sure its out there. I have a 2002 325XI
I am replacing the wishbone/balljoints and bushing. So the new "kit" gives me all the pieces except the bracket that holds the bushing (its just a bear bushing).
Is there a way to seperate the old bushing from the bracket and reuse the bracket. I have a 3-point puller which I have tried and failed.
BobTheBimmer is offline   Reply With Quote
Old 10-14-2016, 09:50 AM   #2
Rtcoleman
My Ride: '05 e46 330xi
I assume you are talking about what people commonly call the lollipop (kinda looks like one)?
You need a press to remove the old bushing and press in the new one. Some shops can do this pretty cheap. There's a Napa with a machine shop right down the road from me that does jobs like that. I think it was $30 and 1/2 an hour for two. Well worth it IMO. If you don't have a press, call around.
Oh, and if I recall correctly, the bushing is not centered end to end in the carrier, so I would double check the specs to pass on to the shop.
Rtcoleman is offline   Reply With Quote
Old 10-20-2016, 10:22 AM   #3
KlausH79
My Ride: 2001 325ti
Hey
You could buy a press like rtcoleman said. I bought an 8 ton press that did the trick but it was quite a write off for just doing two fcab's. However I've also had great success with this universal bearing removal kit
I've removed all other bushings in the rear of my e46 with that kit alone. It works like magic. To use the press you need something like this anyway so I'd try that out on its own first and then see if it works.
Sent from my Nexus 5X using Tapatalk
KlausH79 is offline   Reply With Quote
bushing extractor, bushing tool, control arm bushing, suspension
