Old 10-16-2016, 02:44 AM   #1
Duke898
My Ride: 2001 330Ci
Best ATF replacement kit?
I'm going to have my friend's father flush and fill the ATF, and I thought while he was at it, he might as well put on a new filter and pan gasket. Don't know **** about cars, so I'm hoping for some guidance. Been looking at a few options on ebay...
http://www.ebay.com/itm/BMW-e46-e39-...FUoaCp&vxp=mtr
http://www.ebay.com/itm/361529400437...%3AMEBIDX%3AIT
Duke898 is offline   Reply With Quote
Old 10-16-2016, 04:41 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
https://www.fcpeuro.com/products/bmw...zf-24152333915
https://www.fcpeuro.com/products/vol...ns-fluid-29934 x whatever amount you need
bolt x22
https://www.fcpeuro.com/products/bmw...lt-24101423273
Old 10-16-2016, 04:51 AM   #3
Mr Podman
My Ride: E46 Coupe
As you know, you've got the ZF transmission in that car, and not the GM transmission.
I've always found www.pelicanparts.com to be an excellent source for parts information and parts purchases.
There, you can buy the ZF branded filter kit with pan gasket and drain & fill plugs for $88.50.
podman
Mr Podman is offline   Reply With Quote
Old 10-16-2016, 05:00 AM   #4
Duke898
My Ride: 2001 330Ci
Solidjake, thank you so much.
How many liters should I buy (To fill)?
Old 10-16-2016, 05:01 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Not sure, you'll have to search around.
Old 10-16-2016, 05:37 AM   #6
NZBM
My Ride: 330ci, 325iT, X5 3.0
I bought 14 Litres of Valvoline Maxlife ATF- for 3 drain/fills when I did mine.
If I remember rightly, removing the pan will drain approx. 5 litres, just draining the pan without removing it will drain approx. 4 litres.
I used the ZF filter kit from pelican that MR PODMAN mentioned, all good but from memory one of the plugs was wrong size so ended up reusing the old one.
Clean the old pan bolts up and use Blue Loctite when refitting them.
NZBM is offline   Reply With Quote
Old 10-16-2016, 06:24 AM   #7
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Jake, I think No. 29934 is the wrong Febi ATF. FCPEuro lists that as power steering fluid.
He should use the No. 14738 instead, which is what is shown in his ebay links.
I looked up both on the Febi website (http://www.febi-parts.com). The 29934 is Dexron III fluid, while the 14738 is LT71141 fluid.
///Mmmmmm...
Old 10-16-2016, 06:36 AM   #8
BaliDawg
How much fluid you need depends on how you change it. For multiple drain/refills, it takes 6 liters per. For a full fluid exchange using the cooler hoses it's 9 liters.
ZF 5HP19 ATF capacity:
9 liters including torque converter (full fluid exchange)
6 liters without torque converter (pan drain and refill)
http://www.bmwtips.com/tipsntricks/t...F2000Chart.jpg
///Mmmmmm...
Old 10-17-2016, 11:57 AM   #9
goodmanr
My Ride: 01 325i Sprt&PremPkg
The best? ...I guess that would be genuine BMW parts. You can use an aftermarket filter and gasket if you like; but for the ATF, I would go to the dealer and give them your VIN, they will sell you the exact fluid recommended for your trans. Other fluids might work, but they won't be better and could be worse.
goodmanr is offline   Reply With Quote
atf, transmission
