Sponsored by BimmerWorld
Old 11-01-2016, 09:48 PM   #1
benfisher22
My Ride: 2004 e46 330ci Sport
Bilstein vs. Koni
I need to replace my front struts, and I was wondering what everybody thinks of Bilstein vs Koni struts. Most people I've seen on the forum recommend Bilstein, but is that because it's just the best for the money, or because it's the best period? Konis are sometimes twice as expensive (the ones from Dinan are $240 compared to oembimmerparts Bilsteins for $100). What's the difference? Is Koni worth the money?
Also, anything I should know before I replace my struts? I'm doing the work myself but I'm not very experienced working with bimmers or e46s. Thanks
benfisher22 is offline   Reply With Quote
Old 11-01-2016, 10:46 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
You are planning on replacing the rear shocks at the same time, Right ?
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-01-2016, 11:41 PM   #3
benfisher22
No, just the front.
Old 11-04-2016, 04:29 PM   #4
Rob43
Rob43's Avatar
Originally Posted by benfisher22 View Post
No, just the front.
That would be a mistake...
Rob43
Old 11-04-2016, 06:44 PM   #5
benfisher22
Rob43
Why is that?
Old 11-04-2016, 11:09 PM   #6
Rob43
Rob43's Avatar
Why is that?
Question: When getting dressed, do you put one shoe on only or do you wear both shoes at the same time ?
Rob43
Old 11-06-2016, 02:20 AM   #7
yamman93
My Ride: 2006 330ci
I wouldn't say it would necessarily be a mistake to replace only the fronts. I mean it's safe to assume that if the fronts are bad then the rears are probably shot too but I replaced my rears first actually and didn't do the fronts for another month or maybe even longer. It really didn't seem like that big of an issue. Correct me if I'm wrong of course.
yamman93 is offline   Reply With Quote
Old 11-06-2016, 11:53 AM   #8
Radnor
My Ride: 325Ci
Why give out bad safety information to someone? Give all the options you want on how you think some one else should do something, except when it's a clear safety issue.
Radnor is offline   Reply With Quote
Old 11-08-2016, 04:01 PM   #9
zander271
My Ride: 6spd ZHP/5sp XI
Bilstein vs. Koni
Its not good for a couple of reasons these being the top 2
- increased stopping distance ( this happens because the weight of the car is not controlled as it should be)
-Dampers help keep the tires in contact with the road surface. Not having contact with the road after hitting even a small bump our pot hole can have dire consequences.
OP damper choose really depends on what you want to do with the car. I don't like to cheap out but my budget is very different from others.
- Koni Yellows(Adjustable) if you plan on lowering the car
- Koni Orange if you need to be cheap and lower the car or want to stay stock right height. Don't go lower then an inch or with race springs on these. You would want to keep it moderate on the drop/spring rate.
- Bilsteins B4's if you want to stay 100% stock
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
bilstein, koni, struts, suspension
