Old 11-04-2016, 10:29 AM   #1
PHDE46
My Ride: 2002 330ci vert
How urgent to replace leaking rear shock and possible cracked mount?
Friends,
I know there are probable a million threads on this, but I am concerned about urgency, so please bear with me.
I have a leaking rear shock and there is a sort of rattle noise coming from someplace near there. If I have a busted shock and a cracked mount, how urgent is it to replace? Can I safely drive it at all? Do I have time to order parts and DIY, or should I drive/tow immediately to my indy shop?
Thanks!
Paul
Model description: 330CI
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Engine: M54 - 3,00l (170kW)
Drive: Heckantrieb
Transmission: manuell
Body Color: Titansilber Metallic (354)
Upholstery: Standardleder/hellbeige 2 (arbeitsn (N6HC)
Production date: 31.08.2001
Assembled in: Regensburg
PHDE46 is offline   Reply With Quote
Old 11-04-2016, 10:37 AM   #2
Nicker
My Ride: 323ci
all we can do is guess....
go to your car, remove the crap inside the back of it, pull back the carpet and insulation and VISUALLY inspect it yourself.
This is the only thing to do.
If it looks like this, then it's bad:
Your car being 14+ years old, shocks should have been replaced atleast once, and that means they should have been installed with new mounts and reinforcement plates.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 11-04-2016, 11:31 AM   #3
PHDE46
Yes, that's what I am doing. I peeled the carpet, but I'm not sure exactly where the RSM is. Is it under that insulation-covered thing on the left, or is it further forward? see attached pic
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Drive: Heckantrieb
Old 11-05-2016, 08:31 AM   #4
markusmarkus
My Ride: 2001 330Ci
The shock mount will be on the top of the wheel's inner fender. The pic is of some electronic gizmo.
Old 11-05-2016, 08:54 AM   #5
PHDE46
Thanks. You are right. The RSM is hard to reach in the convertible. Turns out I have to remove the whole top storage tray and surrounding trim pieces just to access the shock mounts. Estimate from Indy shop is $900. Ordered the parts yesterday and will give it a go myself. What could possibly go wrong?
Old 11-05-2016, 10:02 AM   #6
cvx5832
My Ride: 325Ci, 325Cic, C300
Lots. Thankfully that information is incorrect.
The convertible is the easiest to change rear shocks on of all the E46's. You don't even need stands, but I did use ramps for enough clearance to swing my ratchet and torque wrench. This also works out since the car has to be loaded before final torque is applied.
Raise the tonneau and get it to this :
Then access the RSM nuts :
Don't forget the tonneau has a timeout value so you need to work smart, or in increments.
Good luck.
cvx5832 is offline   Reply With Quote
Old 11-05-2016, 10:22 AM   #7
cvx5832
That's the reservoir for the top hydraulics. The tower is what it's mounted on. I'd be hesitant to be moving hydraulic lines unless I needed to.
Don't take it from the trunk, take it from the top.
Old 11-05-2016, 10:43 AM   #8
NorthernCAE46
My Ride: 01 330Ci Convertible
Good luck.
Curious as to what you mean by timeout value? What happens if it's propped open like that for too long?
NorthernCAE46 is offline   Reply With Quote
Old 11-05-2016, 10:44 AM   #9
cvx5832
It starts to close itself automatically, albeit at a reduced close rate.
Old 11-05-2016, 02:47 PM   #10
PHDE46
Thanks, this is great. How do I get to the center nut between the RSM nuts? Don't I have to loosen that nut to remove the bad shocks?
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Drive: Heckantrieb
Old 11-05-2016, 04:53 PM   #11
PHDE46
Mission accomplished!
Thanks to everyone for your help. Replaced rear shocks, DISA, and flush &fill.
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Drive: Heckantrieb
Old 11-05-2016, 05:11 PM   #12
allikanbe
My Ride: 2013 335is vert
Thank goodness for forums like this. I changed my convertible shocks in minutes. So many "mechanics" try to rip off people with BMWs, MBs, etc just because of the name.
allikanbe is offline   Reply With Quote
Old 11-06-2016, 10:27 AM   #13
NorthernCAE46
Which shocks did you go with? How does it drive now?
EDIT:
How would one go about to stop/ or stall this from happening? (I.E what do you do to finish the job? work quick?)
Old 11-06-2016, 11:42 AM   #14
cvx5832
You work smart. Pre-assemble your tools and the replacement shock so you can open the tonneau, unbolt the old and slip in the new before the top reaches the 10 or 15 minute (can't remember) timeout. There's plenty of time.
Or work inefficiently and keep operating the top. And for some reason I remember you can only operate to close it (once timeout is reached) before opening it up again to where you need it. Way easier to just plan the job.
Old 11-06-2016, 11:44 AM   #15
Radnor
My Ride: 325Ci
Now that you have replaced the two rear shocks, when will you replace the front struts? These should always be done together assuming they all have higher mileage on them. Worn out front struts with new rear shocks are a bad combo.
Radnor is offline   Reply With Quote
repair, replace, shocks, suspension
