Old 11-10-2016, 02:19 PM   #1
dmcneice
My Ride: Subaru Outback
Ye olde dreaded Mystery Coolant Leak/Rough Idle
Ok, ladies and gents, I have an issue and would like your opinion. The wife's 330CIc with 200K on it is having some coolant issues. Also it is running roughly at idle and especially at cold start up. Had some smoking issues but I quit cause I hear it is bad for you. The car did too, it is a small amount of oily looking smoke out the tail pipes at start up. I have checked the Expansion Tank, seems fine. I have replaced the tank recently (20K or so ago) and all the hoses, etc. Only thing I have not changed is the Radiator itself and the water pump. No discernible leaks at piping joins, o-rings, expansion tank, sensors, radiator, etc. I have checked while hot and also when cold. No visible leaks. I am getting a low level light when I drive it for about 5-10 miles. Sometimes it is low and sometimes it seems to be over filled in the tank. I am always careful to NOT overfill that dang thing as I know bad things can happen.
When it was smoking badly, it did seem to be losing coolant out the tail pipe. I had it in the garage and they did a pressure test and said it is fine. Some other work was done unrelated to this issue. Smoking issue has died off to almost nil. Using some "fuel injector cleaner" per garage recommendation.
So, is it a sensor malfunction, weep hole on the pump, or wor$e? What say ye? How do I test the sensors? Will an Ohm meter give me a reading on it and how do I know what the correct value is? Got questions, need more info, let me know. Thanks in advance for any help you can give. Oh, and I almost forgot, it is Titanium Silber in colour!
dmcneice is offline   Reply With Quote
Old 11-10-2016, 02:29 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If it's oily looking smoke I'm confused that you think it's losing coolant out the tailpipe too.
But, look into CCV. Very common failure especially if you haven't replaced it at 200K miles.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 11-10-2016, 02:34 PM   #3
dmcneice
The colour and volume of smoke has diminished greatly over the last two weeks since it has been out of the shop. Now it is just a wee bit of oily smoke, no where near what it was before. When I first noticed it there were great volumes of smoke and it seemed more vapour than emission/oil at that time.
Old 11-10-2016, 03:40 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Spend $30 and buy the OBDFusion App for your phone or tablet and then get the proper VeePeak interface from Amazon.
Android requires Bluetooth, iProducts requires Wifi.
Then read the PDF in this thread regarding OBDFusion - http://forum.e46fanatics.com/showthread.php?t=1097893
Check the temperature sensor in the lower radiator hose. the O-ring on this sensor leaks all the time, usually after 5 years. Only leaks when the engine is cold. If you see any staining or moisture under the sensor on top of the lower engine cover, replace the O-ring, simple, cheap and requires not tools or draining of the cooling system.
Time to read these threads -
http://forum.e46fanatics.com/showthread.php?t=1115860
Old 11-10-2016, 10:10 PM   #5
IxNay
My Ride: 2000 328Ci 5sp SP
Sounds like CCV (if you're lucky) or head gasket (if you're not).
IxNay is offline   Reply With Quote
Old 11-10-2016, 10:44 PM   #6
Kpriest
My Ride: 2005 325i
How is your oil level? Are you having to top that off as well as coolant?
Kpriest is offline   Reply With Quote
Old 11-11-2016, 07:43 AM   #7
markusmarkus
My Ride: 2001 330Ci
These engines have 2 plastic cooling pipes that have o-rings. See items 6 and 8 in http://www.realoem.com/bmw/enUS/show...diagId=11_2200.
At that mileage the o-rings may be shot. Also be aware that the aluminum head may be corroded where the pipe and its o-ring are inserted into the head.
I'd check the valve cover gasket in addition to the CCV. They do leak.
coolant leak, rough idle
